McLeod dual disc clutch
Anybody running one? Thoughts? Considering it for my very heavy 65 GP and T-56.
Any better suggestion? SOB is not inexpensive. https://www.jegs.com/i/McLeod/673/6913-07/10002/-1
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool |
I'm running the RXT ceramic version, it was grabby first time I clutched it I was like wow....then it broke in a bit and its much better now. Will take some rpm burn off the line to get the pig moving, good clutch. What gear and tranny 1st ratio u running? How much power in engine?
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
I bought one and haven't installed it yet. It is supposed to have less than stock pedal pressure with the ability to hold over 600 ftlbs of torque. I also got the ceramic version, as the company tech guy said it was much more durable and would not burn up under hard use.
I bought the RXT (ceramic) with my T56 and have installed it but not ran it yet.
Of all the dual discs I looked at it seemed the best ratio of cost/capability.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Google it and you will see some reviews. I have the rxt and yes grabby as it does not have any torsion spring to absorb any initial grab. Sent mine back for chattering but one I got back was the same, and after a while it does seem to get better. I would have went with a good single disc next time. We called Mcleod and they recommend this due to weight vs horse power. Also found that mechanical linkage does not like the rxt, I guess to much pressure for the mechanical linkage, so now swapping to hydraulic.
64 Lemans hardtop 4spd, buckets |
Put in mine (RXT) with the T56 Magnum swap. Went with hydraulic clutch. Works very well so far and I like it.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
Yeah, no sprung hubs on the discs, they will be grabby, and lock fast and hard. They started offering the ceramic discs due to people slipping them because of how grabby they can be. But, they hold good under considerable power.
The SPEC 3+ setup is a single disc, hybrid material, sprung hub, and rated at 900 ftlbs. Its a much better option, and the SPEC 3 is a little more friendly on the street, rated at 780 ft lbs. http://www.specclutch.com/cars/Pontiac/GTO/1970/Single Can see the description of their' different levels here: http://www.specclutch.com/products Can look at the 2 and 2+ as well, if you're under 650 ft lbs. I've recommended these to a number of people who have detroyed many of the 'main stream' performance clutches, and they couldn't be happier. I just got a 3+ for my 'bird, which will be over 700 ft lbs, will provide feedback in the spring. Be sure to call and talk to them before you order, they may recommend other compatible part numbers than what's listed on their' site. .
Great advice, as one can expect here. Thank you all.
