Has anyone used the subject Teflon gasket, it states it can be reused ?
I was wondering if sealant is still needed with this gasket or you can reuse it without anything else. And what torque do use for this type of gasket? Thanks Bob,
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph |
I have not used that gasket, but have used the Teflon timing cover gasket. Worked well with no sealant.
I would just install and tighten to factory specs with no sealer, just like the regular gasket
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
![]() Quote:
I planned on using Ultra black on the side that mates to the bracket but nothing on the surface that mates to the block. On my drag car it's easier to remove the three bolts at the bracket and then replace the filter on the work bench.
I have used that gasket numerous times with no problems.
