Old 09-28-2018, 06:26 PM
allenga allenga is offline
Default Torque Spec - 400 - Fan Assembly to Water Pump
Hi Guys, the 4 nuts that attach the fan to the studs on water pump. I can't find the spec. Anyone point this out in the shop manual. Thanks!
Old 09-28-2018, 10:41 PM
ZeGermanHam's Avatar
ZeGermanHam ZeGermanHam is online now
Unlike engine internals and other sensitive areas, I don't feel like this is something which warrants being finicky with torque specs. Just snug it down appropriately. You can use threadlock if you are paranoid.
1998 BMW 328is (track rat)
Old 09-28-2018, 10:46 PM
thx
Old 09-28-2018, 10:58 PM
tom s tom s is offline
What kind of setup has studs on the pump flange?All of mine use fine thread bolts?Tom
Old 10-03-2018, 12:57 AM
Sprocket's Avatar
Sprocket Sprocket is offline
I don't think I have ever had one with bolts instead of studs and nuts. Yes, 5/16"-24 fine thread is correct, but bolts only...?
To answer the OP's questions, just tighten them down without going gorilla strength on the nuts. I use lock washers between the nuts and the fan hub.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 10-03-2018, 01:01 AM
Sprocket's Avatar
EGAD! I just read my '70 shop manual which references "Bolt-Fan and Pulley to Water Pump" 20 lb-ft. That being said, every one of my Pontiacs in the past has had a stud and nut setup on the fan mount. How long of a bolt do you use?
'70 GP Model J
Old 10-03-2018, 01:08 AM
Sprocket's Avatar
And I see Ames sells both bolt kits and stud & nut kits. They say "check your original before ordering."
'70 GP Model J
Old 10-03-2018, 09:40 AM
Thanks!
Old 10-03-2018, 10:14 AM
Is this a clutch fan application!I have never used a clutch fan.All of mine use a fan blade to a spacer with bolts holding them to the water pump flange.Tom
Old 10-03-2018, 11:46 AM
Sirrotica's Avatar
I pull on the wrench until my wrist says, "That's plenty tight"...………….
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-09-2018, 11:44 PM
highway star's Avatar
highway star highway star is offline
77-78 TA clutch fans with studs are OEM.
Old 11-10-2018, 12:12 AM
Got it.Tom
Old 11-10-2018, 09:57 PM
64speed's Avatar
64speed 64speed is offline
My 64 uses bolts
Old 03-25-2019, 09:10 PM
Make sure your split lock washer end is not in the slot opening of your clutch fan. It should be located on solid material.
Thread Tools
Display Modes
