Old 09-10-2018, 02:29 PM
tolerico tolerico is offline
Default Correct engine paint color 1969
Can someone clarify what the correct engine paint color would be on a 1969 Pontiac 350 Firebird ?
A friend is looking at this car on ebay and said the seller states the 350 engine received this blue color paint....
https://www.ebay.com/itm/11323211355...p2471758.m4704
Thanks.
Old 09-10-2018, 02:32 PM
350 color
Old 09-10-2018, 02:39 PM
rwfisher's Avatar
rwfisher rwfisher is offline
That looks closer to the 1973 color to me but hard to tell.. Definitely not the '67 color....
Old 09-10-2018, 02:41 PM
Hikin Mike's Avatar
Should be a metallic blue. https://secure.amesperf.com/qilan/De...A&web_access=Y
- Mike
Old 09-10-2018, 02:42 PM
Thanks.
Old 09-10-2018, 02:44 PM
Hikin Mike's Avatar
Originally Posted by tolerico View Post
Should it be the same blue metallic color as seen on 400 engines in the late 60s?
Not an expert, but I don't thing they changed the engine color based on motor size. It should all be metallic blue.
- Mike
Old 09-10-2018, 02:45 PM
JMB36TA's Avatar
JMB36TA JMB36TA is offline
It should be the light blue metallic. Click image for larger version
Old 09-10-2018, 02:48 PM
JMB36TA's Avatar
Here’s a link to the paint I used. It’s the closest I’ve seen to the original color
http://www.hirschauto.com/mobile/AER...ON%20MET%20BL/
Old 09-10-2018, 02:55 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
This link might be helpfull: http://pontiacpower.org/enginecolor.htm
Old 09-10-2018, 03:04 PM
Thanks all. I sure thought it should be the metallic blue color.
Old 09-10-2018, 05:18 PM
thepontiacman's Avatar
Default paint for engine
I use Plasti-Kote #227 Pontiac blue metallic .
Old 09-10-2018, 05:20 PM
Dick Boneske's Avatar
Ditto on the PlastiKote #227. Easy to find, reasonable, easy to apply, durable.
BONESTOCK GOATS
'99 Bonneville SE Sedan
