Old 09-04-2018, 08:52 PM
grd777 grd777 is offline
Default hood hinges for a formula
are the hood hinges different for a 1972 formula i know ford made different ones for the 71 mustang ram air hood
Old 09-04-2018, 09:03 PM
Formulabruce's Avatar
Nope, same 70-81
That said the 1970 are put together different and have Identifiers, but work the same.
They can be rebuilt with brass bushings, and on Formys I have elongated the slots to let the hood sit a bit lower.
Old 09-05-2018, 01:34 PM
tdavidl's Avatar
tdavidl tdavidl is offline
... and on Formys I have elongated the slots to let the hood sit a bit lower.
would you mind posting a pic of the slot you're referring to & have you done this due to the warping of these hoods or other reasons (to lower it) ...thx
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 09-05-2018, 03:34 PM
There are ONLY 2 slots in a Firebird hood hinge.. I have elongated Both towards the Hood, ( Upper side of slots) to allow the hood to set a bit lower. This is somewhat due to warpage, but also to the design on the fiberglass itself.
Afterwards I do a newspaper test on the cowl seal.
Old 09-05-2018, 06:50 PM
ponyakr's Avatar
ponyakr ponyakr is offline
I too need some hinges. A local guy has some used ones for $75. But, I see new(or refurbished) ones for about $100 or less.
So, are there certain brands there are not good quality, and some that are ?
https://www.ebay.com/itm/1970-81-Cam...4383.l4275.c10
https://www.partsgeek.com/ss/?i=1&ss...070l&x=21&y=13
https://www.partsgeek.com/3k35r94-po...iac+Hood+Hinge
https://www.summitracing.com/parts/g...model/trans-am
Old 09-05-2018, 08:23 PM
I have found trial and error for even new ones with the formula hood.
Old 09-05-2018, 08:32 PM
johnta1 johnta1 is online now
Edited:
Can't read I guess.
Old 09-05-2018, 08:38 PM
Bentwheelbob's Avatar
Bruce is correct. I think we went through three sets of original hinges for the Black Car to find a matched pair that provided the desired fit. His suggestion of slotting the holes is well advised.
Sent from my iPad using Tapatalk
Old 09-06-2018, 07:11 AM
Poncho Dave Poncho Dave is offline
It is recommended to keep a fiberglass hood unlatched while in storage so there is less chance of warping the hood.
Old 09-06-2018, 07:13 AM
70 hood hinges have an extra plate welded on them.
Old 09-06-2018, 06:29 PM
FunctionalShaker FunctionalShaker is offline
You can elongate the holes for steel hoods as well, if you have a weak hinge. It's too bad the spring is under tension with the hood closed.
