Intake Carb pictures needed
I'm trying to get my carb/intake sorted.
I need pictures of original 68 GTOs with air cleaner removed. Of specific interest is the PCV nipple on the intake (seems awful close to fuel inlet), the vacuum port at the rear of the carb for cars WITH AC, PB, hideaways and Auto Trans. (the complicated adapter that screwed into the rear of the carb) The vacuum line from carb/intake/TVS to dist., auto trans vacuum line. Any plugs and nipples in the intake manifold. Lots of under hood pictures out there but not many original cars with the air cleaner off. So many cars have had this stuff modified or changed in some way it's hard to sort out. |
Won't be much help but I think the '68s had at least one hollow stud for the carb mount used for vacuum. True that the PCV fitting is very close to the fuel inlet...I believe that is correct as far as that goes.
Part of the reason for this response is to just see if I can do it. I can only read one in maybe twenty threads.
Greg Reid Palmetto, Georgia |
I've got mine sorta setup in the right way. My vacuum fitting on the back isn't an original, but it's close. I've got a diagram somewhere - maybe in the resto guide. I think the hollow stud was on the manual cars?
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
I installed the Qjet bolt kit from Ames and it has the hollow stud ... far as I can tell from the 69 assembly manual it goes on the right side rear ... didn't specify auto or manual. I think it's just a testing port, not used for anything.
PCV fitting is ok now with a gasket under the carb. I did find a place in the assembly manual (again for a 68 not 68) which shows me what back size vacuum fitting I should use with auto and PB. Getting close now, just need the fitting for the line to the vacuum switch in the air cleaner, and have to find out if I need the hard line which bolts to the top of the carb and goes from somewhere to somewhere |
Dataway, here’s a few pics of the setup on my 68 with AT, AC, and PB. I think it’s correct but no guarantees. If you need any other pics let me know. Easy to take without hood and fenders.
Don't rush me - it's only year 20 of the 3 year restoration! 68 GTO convertible YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track, P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways C1 224 Triple white |
Perfect, just what I'm looking for. I think my rear fitting is a tad different with Hide-aways ... at least a "T" of some sort off the back for the doors.
What is that line that bolts to the carb called? It supplies vacuum to the TVS right? I'll have to bend that a tad since I am using a 71 carb and the vacuum port is pretty much right below the fuel inlet ... just to the left a bit, but not as far to the left as a proper 702 carb. I think the rear fitting I need is the Ames N139PV but with the "T" coming off the red stripe line that comes out the side. Pretty much what you have there. In 69 I think they went to the angled side outlet. Thanks for the pics, going to save those for reference. BTW, where the hell did you get an idle solenoid?? Would love to have one on mine since the throttle arm has the provision for it ... but they are hard to find ... I guess even one not working would be better than none at all. |
Just wanted to add these to this post in case someone is doing a search later on, they'er from post https://forums.maxperformanceinc.com...d.php?t=820964.
Good stuff, Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
Illustration I found in GTO restoration guide is helpful, although still not sure about the connection for hideaways.
From what I can find ... the 68 uses the fitting that goes straight back to the PB hose barb, and has a smaller port coming straight off to the side. This smaller port got a T fitting sending one side of the T to the hideaways.
69 used a very similar piece, except the small barb came off at an angle. I think. |
I was wondering how it might be piped for a manual tranny with standard brakes, be nice to have photographic examples of all the configurations.
Frank
I think manual gearbox with manual brakes it just has a small barb sticking out and that's it.
The Ames catalog has got pictures of a few of them with their application. |
Sounds about right, I sure do like simple.
Mater a fact, been told I'm simple. Frank
Dan |
Thanks for the images Dan, should have added my car does have hideaways, certain these are going to help many people in the future.
Good stuff, Frank
Helping me already
I have a 54K original mile 68 4sp with hideaways... I will throw on some pics for you
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
See ! Great thread data, I'll go ahead and blow those up for ease of viewing... Pretty sure that white valve hanging on that hose here in the first pic is the check valve coming from the hideaways. If I'm not mistaken it goes to the fitting that's plugged at the back of the carb in pic 4. Thanks again, Good stuff, Frank
Sweet .... saving those photos for sure.
Take some more ... like the left side wire looms and starter wiring .... and everything else |
Good to see you're still lurking here Kurt!
Hey Greg- craziest past two years of my life! I'm still here and angling for more Pontiac stuff soon. Kids, wife, new house, new job, family illness....Just wipes out time. We're all good. I'll post more picture in response above.
