2 barrel to 4 barrel conversion
Friend of mine bought a 70 Lemansl. It has a 350 with a two barrel and he would like to put a four barrel on it. Is there much to be gained by doing the swap? Or is the factory cam going to prevent any real gains?
Would probably need to upgrade the cam at the same time to make it worthwhile
Sent from my iPhone using Tapatalk |
You will pick up a little, but do not expect it to feel like you just installed a magic bullet. Fuel economy will probably go down.
Any recommendations on a cam for this? It probably still has the original 2.56 gears.
If his motor is still in good shape then he should pick up 15 hp just like the factory ratings showed.
Just note that the 4 bbl motors do make use of a different fuel pump with more volume , so as long as he does not switch over to bigger Cam it may be ok. You will know real quick when the moor does not want to rev above 4500 or so!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 06-11-2018 at 02:14 PM. |
Your mileage may in fact improve if you can keep your foot out of it. Small primaries on the Qjet make it efficient.
Been there done that,
Do it and dont look back its been so long ago i cannot remember the order but i changed out the cam and went to a q,jet, my cam had some real bad lobes it was toast, and i just went mild 204 duration and .411 lift SINGLE pattern Isky What that process did was vastly increase midrange it was also a 1970 350 with #11 heads
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
What about the rest of the set up? Dual exhaust? Does it pass a compression test? Engine "tight" little to no blow by? He's going to need the 4-barrel throttle bracket. I've done this exact thing to a 70 Lemans I had because a rocker stud broke. I put a set of 13's on it, Q-jet carb, intake and a dual exhaust. I didn't touch the cam. The difference was nice. I did however have a 3.23 gear ratio.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
my understanding, is that there will be no real gains, unless other stuff is swapped to see a real benifit...
As it stands, it's mostly a status thing... |
If you were driving much on 2 lane roads in the farm country, the 4 bbl carb might make passing a bit safer as you could get around the other vehicle a bit quicker.
Most F.E. depends on the driver behavior. Q-jets do have smaller primaries and could give better F.E is tuned properly to work with your 2.56 gear. So my opinion is the drivability/MPG/passing ability might improve a noticable amount but the HP/Torque would maybe change slightly. During normal driving with the engine the 2 carbs should be basically transparent. A good calibration is a good calibration bs it a 2 BBL or a 4V Q-jet. Tom V.
I'd tell him save his money and wait until he could change cam, heads, exhaust, and fuel system. I learned this lesson on 350 Chevy years ago, complete waste of money for me.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I've done this a couple times on cars that had 350 2bbl engines when I got them. If all you do is put on a 4 bbl then you won't notice much improvement at all.
If you install duals your mileage will improve but no additional power will be noted past 3000 rpm. But if you put a mild cam in the engine and the duals and the four barrel yes, it will really wake up. If it has 2.56s then get a duplicate of the 067 factory cam that came in the majority of automatic GTOs. Replace the timing chain and lifters of course. You don't have to pull the heads. |
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
This sounds like a good idea to me. If the heads have press-in studs, a cam with more lift and/or a steeper ramp, coupled with stronger springs, could pull out a stud. https://www.ebay.com/itm/Melling-SPC...EAAOSwOVpXZx6n https://www.ebay.com/itm/Engine-Cams...QAAOSw-vda1dCi To me, this brings a question to mind. For you guys who have run larger cams/stronger springs with press-in studs, what's the biggest cam/strongest springs you have run, without pulling a press-in stud How many think an 068 would be safe ? How about a Summit 2800 ? https://www.summitracing.com/parts/s...RoCCWIQAvD_BwE How about a Crower 60240 or 60915 ? https://www.crower.com/pontiac-287-4...m-270-hdp.html https://www.crower.com/pontiac-287-4...cam-272-h.html OR, is ANY cam a crap shoot, with press-in studs ? |
The car does already have dual exhaust. I was thinking that swapping in a rear with 3.08 or 3.23 gears may be a better option
