Old 04-18-2018, 11:42 AM
70peppergreen 70peppergreen is offline
Default looking for 3 templates for my 70 GTO
I am looking for 3 templates for my GTO
Hood Tachometer layout
Rear deck lid spoiler
Hood Pins
I have seen a hood pin layout but cant remember where
I called inline tube and they don't sell the templates separate
These are the templates you use to drill holes into the car with
Thanks As Always
Old 04-18-2018, 01:18 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
Hood Pin installation drawing:
http://www.gt-37.org/gallery/picture...159/category/8
Hood Tach installation drawing:
http://www.gt-37.org/gallery/picture...160/category/8
1971 GT-37 - 350/M38, Rosewood Metallic/Black
www.GT-37.org
Old 04-18-2018, 02:18 PM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is online now
I think Ames supplied me a template for the deck wing when I asked them, they emailed it to me.
Old 04-18-2018, 03:59 PM
Called Ames the spoiler they have is not close to the original the details state that the posts are wider than original
The unit is injection molded and does not use studs to mount.
The templet will be incorrect.
There is a temp let you lay on the hood and shows exactly where to drill
There is a templet that lays on the trunk and shows where to drill
I guess you have to buy the parts to get the templet.
I think for the hood pins there is only the factory detail
Old 04-19-2018, 07:58 AM
HWYSTR455's Avatar
Bummer. So the posts are wider? Like in thickness, or spacing apart from each other? Not sure posts/screws/bolts would make a diff in where the holes go?
I thought the trunk lid has braces and it's obvious where the holes go? Or am I thinking of the 442?
Old 04-19-2018, 09:53 AM
johnta1 johnta1 is online now
Try a search on PY?
I know there has been at least one post (with diagrams) on the hood tach and think on the hood pins.
Also seems there was one on the rear spoiler, but could have been Firebird?
I have a pic for 69 Bird but no A body.
(that I could find anyway)
Old 04-19-2018, 11:04 AM
Paul E Paul E is offline
Do not cut the hood until you check the template for the tach on some thin cardboard. There are a few different mounting patterns
Paul
Old 04-19-2018, 03:10 PM
Thanks for the hood pin detail
the across the front dimension says 20.5 across
but the right hand says e of car or 3 of car ?
does any one know how to read this detail
thanks
the 3.5 dimension appears to be from the back of the radiator support top to the front this looks easy
Old 04-19-2018, 03:56 PM
UPC-WU2's Avatar
It’s a C/L symbol which means the ‘centerline’ of the car.
www.GT-37.org
Old 04-20-2018, 10:50 AM
thanks now makes perfect sense
Old 05-02-2018, 11:31 AM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
Here is one with pins
ID:	482151   Click image for larger version
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
