Old 04-05-2018, 11:14 AM
70peppergreen 70peppergreen is offline
Default 70 GTO - Where does this part go
I don't know where this part goes
I marked the bag "lower radiator support"
I believe that is the general vicinity
I looked everywhere in my books and online
Just put the radiator core support in possibly is in the bolt set up there?
I thought I would post a picture of my 70 GTO
Getting ready to put the clip back on.
Fully detailed with my body work skills ?
ID:	480035   Click image for larger version
Name:	70 front clip.jpg
Old 04-05-2018, 11:19 AM
SONIC 4 U's Avatar
SONIC 4 U SONIC 4 U is offline
Top of core support to hold to chassis
http://www.AbsoluteCleaner.com
Old 04-05-2018, 11:28 AM
Do you know where I can get a picture or detail that shows this
I still don't understand
Sorry
PS
the frame and cowl are fully detailed
The suspension is fully rebuilt
Old 04-05-2018, 12:08 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
If you are that deep in a restoration you need to invest in the shop manuals. You’ll be happy you did.
https://rover.ebay.com/rover/0/0/0?m...2F222064241659
https://rover.ebay.com/rover/0/0/0?m...2F161811822413
https://rover.ebay.com/rover/0/0/0?m...2F140815098184
Old 04-05-2018, 12:15 PM
mlewisariz mlewisariz is offline
It is the nut for the lower core support mounting bolt. Order is the long bolt , large washer,rubber bushing,core support,rubber bushing,large washer,then bolt goes thru large hole (about 1" dia) in bottom of frame horns,w/another large washer then the captive nut shown.The tang will then keep the nut from turning without using a wrench on the nut. I have seen some installs without the washer under the nut.
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
Old 04-05-2018, 03:03 PM
Thanks so much I am going to install tonight
The tang faces down to lock in
I believe this is correct
Old 04-05-2018, 05:46 PM
The tang goes up.The bolt and rubber bushes sandwich the core support and then go on the bottom of the core support,then the nut goes inside the frame horn and the tang keeps the nut from turning 360 degrees inside the horn. You don't want to tighten the bolts all the way until the rest of your front sheet metal,bumper brackets,bumper,and valence go into place with proper alignment
since you may need to loosen the bolts to move the core support side to side or forward or back slightly. Once the other parts are in place you can't get a wrench inside the frame horn,hence the captive nut.
Mike
Old 04-05-2018, 06:35 PM
tripower's Avatar
tripower tripower is offline
This is from the 71 assembly manual but should be same on a 70. Part #15 is the nut in your pic.
Oh, and check out the special core support bolt if your car was built in Atlanta in 71
Norm J
Old 04-05-2018, 07:51 PM
eric65's Avatar
eric65 eric65 is offline
Default 70 rad core
core original
hope shows well
ID:	480062   Click image for larger version
ID:	480063   Click image for larger version
ID:	480064   Click image for larger version
ID:	480065   Click image for larger version
Old 04-06-2018, 11:34 AM
Thank you for all the pictures (WORTH A THOUSAND WORDS)
I have a ton of GTO restoration and reference books but could not find the detail or picture for these two
The forum as always came to the rescue
Thanks for the PICTURES AND DETAIL will fix this weekend
THANKS py online
