Old 03-07-2018, 09:20 AM
Default Ames front end rebuild kit
I can't seem to find it. Maybe it doesn't exist anymore. If it's still around, has anyone bought it? Whats inside?
Im going to rebuild my front end, keep it stock but put in a 1.25 sway bar. Ive got the sway bar.
Old 03-07-2018, 09:27 AM
Qball's Avatar
Qball Qball is offline
Page 302 of the latest catalog, my man!
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
Old 03-07-2018, 09:33 AM
Thanks, Mike. I wonder which kit I need. there are two.
Old 03-07-2018, 09:34 AM
Now that I think about it, I already have a new sway bar. So maybe I just need to source the parts myself. That sway bar is $100. Hmmmm.
Old 03-07-2018, 09:50 AM
Qball's Avatar
If you did go with a kit, look at your lower control arm bushing. It’ll either be round or oval. That’ll tell you which kit you want. But if you piecemeal it out, add up your costs. It may be that the kit is still a better value. You could always sell the stock front sway bar.
- Mike
1967 GTO
Old 03-07-2018, 09:55 AM
gtospieg gtospieg is offline
These kits do NOT include the sway bar...they only mention the size of the bar so you get the correct kit with the correct size bushings for the bar you have
Old 03-07-2018, 01:41 PM
GT182's Avatar
GT182 GT182 is offline
May I suggest a 1 1/4" front sway bar. I have one on my 66 GTO and I love it. It's far better than the smaller ones.
It's not in the kit but still go for it. You'll be glad you did in the long run.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-07-2018, 06:37 PM
Qball's Avatar
Paul will be using the 1.25” front seat bar. But you’re totally on the money. It is a great improvement. I have one on my 67. Love it.
- Mike
1967 GTO
Old 03-07-2018, 11:49 PM
fyrffytr1's Avatar
I used the kit from P-S-T.com but wish I had went with the rubber instead of the poly. The squeak and pop every time I go over a bump.
Old 03-08-2018, 01:21 PM
mcmurb mcmurb is offline
I bought this kit for my 67 rebuild this fall. Very satisfied with components. Beware mission creep, ie as long as the drums are off, might as well re build brakes. As long as the control arms are off, might as well do shocks and springs, etc etc.
Old 03-10-2018, 11:41 AM
GT182's Avatar
I have the polyurethane bushings on mine and they don't make a bit of noise. When you install them you need to lube them up really good. The lube was in the bushing kit I bought. You could take them apart and even use wheel bearing grease to lube them if you want. I did that on my 79 Formula way back when.
Gary
Old 03-11-2018, 03:35 PM
Thats the mone that I bought. Its going in with this rebuild.
Old 03-11-2018, 03:39 PM
Brakes and shocks are new. The car doesn't bounce at all and I like the front ride height. So I'll keep the springs. I have no idea how old they are.
