I see there are OK stamps for the engine reproduced but there are multiple options. OK-1, OK -2 and so on.
What would a 1966 tri power Fremont built car have or is there any way to know ? And yellow or black paint ? |
Aren't those the ones with the sticky backing? I've never seen them last for very long once you had the car out on the roads. Heat would breakdown the sticky backing and they'd fall off. Better get a bunch of them to have on hand, unless you plan on trailering it to shows.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
These are just the stamps you put paint on and stamp the RH head .
I would guess OK-1 would be first shift, and OK-2 second shift.
Or - perhaps OK-1 was a certain inspector and OK-2 was a different inspector. In either case I don't think there is any way to know now if yours was a "1" or a "2". Some plants have a paint stamp indicating "electric test ok" and first shift or second shift but that would be specific to the body; the OK stamp would be specific to the engine and the shift would not necessarily be the same. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
It must be the inspector, because I think you can get up to OK-5 .
So it sounds like there is no set rule by year, model or plant. they say either yellow or black. I wonder if that has any specifics or it was whatever paint they had handy. |
Informal assembly plant processes (not defined by engineering) were usually whatever they had handy.
We used to pick up tire crayons off the floor and re-use them for marking the front of dash, or for checking options off the build manifest. K
It would seem that's the case.
On a related subject, is there any way to know what firewall paint stick markings a car most likely would have left the factory with ? or at least something that theoretically should be correct ? |
First photo is a 12,000 mile Catalina. This black stamp (OK-1) is on the RH valve cover.
Second photo is my 65 GTO with the black stamp (OK-5) on the RH head. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
![]() Quote:
The only marking on the firewall of my Pontiac Michigan built GTO is a big “A”, presumably denoting “Starlight Black”, in white marker. You might also find a build sequence number on the firewall or front end sheet metal but you might not recognize that's what it is. By comparison some Chevy pickups have a short novella, showing model number, transmission type, brake system, AC vs no AC etc. The only way to be certain is to document any marks you find before you start and replicate them when you are done. You could find a car that was built in the same timeframe at the same plant and duplicate what it has, but at that point you are just making stuff up so you may as well do whatever you have in mind. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 03-06-2018 at 11:03 AM. |
Here are some of the threads I have accumulated that deal with graffiti, assembly line marking and grease pencil markings (if you are interested):
Factory Markings: http://67-72chevytrucks.com/vboard/s...ighlight=Linda Need Help Deciphering Factory Grease Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda Show Us your Crayon Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda Factory Grease Pencil Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda Z Code Fremont Asssembly http://67-72chevytrucks.com/vboard/s...light=graffiti Found my Build Sheet: http://67-72chevytrucks.com/vboard/s...light=graffiti Numbers at top of firewall: http://67-72chevytrucks.com/vboard/s...d.php?t=545345 K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 03-06-2018 at 10:57 AM. |
