Old 02-20-2018, 10:53 PM
ejw's Avatar
ejw ejw is offline
Default 2nd gen chromoly crossmember
Is there anyone out there that makes a chromoly crossmember for a 1970 Firebird. I have a crossmember from Smith racecraft for 67-69 firebird that fits when I was running open headers. but after adding 3' exhaust, I had to go back to stock piece due to large tube size of racecraft crossmember not allowing exhaust clearance.
I thought it saved 7-10lbs
Old 02-21-2018, 07:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
G Force/Summit have ones that have a big U for the exhaust but not chrome moly and about 5-7 lbs heavier that the stock one.
Skip Fix
Old 02-21-2018, 09:22 PM
ejw's Avatar
ejw ejw is offline
Trying to go lighter. Stock crossmember works, but chromoly is half weight. Can't believe not more options out there for bolt on pieces like this
Old 02-22-2018, 07:38 PM
Skip Fix's Avatar
I was going to a TH 400 in mine and got the Bowtie Overdrive-lighter than stock but straight no exhaust humps. Got the G force -heavy SOB looks like 1/4 steel! Used a factory TH350 I swapped the tab top the other side. Made a 2x4 Jig to weld it on with.
Skip Fix
Old 02-22-2018, 08:13 PM
455firebird1969's Avatar
Did you check Chris Alston’s Chassisworks?
Old 02-22-2018, 09:13 PM
goatless's Avatar
goatless goatless is offline
Just looked over there, looks like they've got a few choices- https://www.cachassisworks.com/c-799...gm-f-body.aspx
1966 GTO
Old 02-22-2018, 10:25 PM
ejw's Avatar
ejw ejw is offline
Thanks, I sent them email. They are tubular steel so not sure if much weight diff for price. Racecraft chromoly piece was super light, just bulky no room for exhaust
Old 02-23-2018, 08:59 PM
ejw's Avatar
ejw ejw is offline
Fyi, chassisworks emailed me back - 15lbs w/ adapter and $300 w adapter. Stock only weighs 8.5lbs.
I guess I'll stick w stock piece
Old 02-23-2018, 10:05 PM
deleted
