Old 12-10-2017, 02:54 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Default Carnage / Trophies
This was the last straw with a 4 speed, I snapped the main shaft in my toploader.
My heavy A body and too much Pontiac power. Now it will be a trophy on the wall. Any of you guys save busted stuff?? I did buy a new main shaft and think I have the 4 speed assembly sold. I must say the ford toploader held up better than the T10 and the TKO 600.
Old 12-10-2017, 03:09 PM
Cliff R's Avatar
Cliff R Cliff R is offline
I busted a Munci decades ago testing a new carb we built for a pretty "mild" 455. I pulled 2nd gear and hit it hard, went to "neutral" (snapped the main shaft). The only problem with what I did is that the customer was in the passengers seat at the time......OOOPS!
A few years later I was testing a pretty stout 455 in a later T/A and it had the Borg Warner Super T-10 (upgraded for big power). Same exact deal, did a full throttle start, tires spun a bit, grabbed second pretty hard...tires spun a bit then hooked hard.....and BOOM!
I have next to no luck at all with manual transmissions behind Pontiac engines and these days for sure I do NOT do any road testing with them after we have done carburetor or other work for the owners!.......Cliff
Old 12-10-2017, 03:15 PM
ta man ta man is offline
I'm keeping this cracked th 350..when I redo the shop bathroom I may use it as a urinal..just need to seal the crack up.
Name:	tranny crack.jpg
Old 12-10-2017, 03:20 PM
JSPONT's Avatar
That was 3rd gear when it snapped! I also saved my old piston I broke the ring land off of also.
I like the urinal idea!!!!!
Old 12-10-2017, 03:32 PM
Formula496 Formula496 is offline
Broke a th400 bellhousing in the Olds. Didn't even know. Went to pull motor for the winter to do some upgrades. Good thing I didn't go one more round that season.
Broke the #4 main web on my 496 Olds. Should have went with my gut and bought a block girdle. Caught it before it became a total yard sale.
Pulled the ring gear bolts out of the ring gear on the Cutlass. Just came through the lights and let off and loud bang then the motor shut off. Figured it blew up and coasted off the track. Got out looked underneath and didn't see anything. Got back in and it started up oil pressure was fine no weird noise. Then the car started to roll a little but was in park. Shut the engine off the car rolled but the driveshaft didn't. Got real lucky with that one. If the rear had locked up at 120 mph I might not be here today.
1992 Pontiac Formula race car
1965 Olds Cutlass race/street car
2016 SRT 392 Charger 1 of 113
Old 12-10-2017, 06:00 PM
Firebob's Avatar
Firebob Firebob is offline
Oh yeah, I save almost everything. One of these days I'll collect it all and put it in one place. I got one same way Cliff described. Carb upgrade over winter, first time out in spring and grabbed second. Made it back home cause it was a couple of blocks away. M20, first and second gear trashed. Input shaft trashed. That carb upgrade cost me a lot of dough. Got broke Pistons, snapped rods. Probably a bunch of other stuff too all sittin on shelves around in the garage.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 12-10-2017, 06:07 PM
JSPONT's Avatar
I see all the grudge race guys winning trophies from old parts welded together. I think it is rel cool. Should have been saving all the hurt parts!!
Old 12-10-2017, 06:09 PM
Whats the expectance of a M22 assembled with a SuperCase & steel mid plate living for a good while at the track on new G70-14's, (mid 1.90 60ft's) behind 518 hp/547lbs of torque ???
Old 12-10-2017, 06:26 PM
Formulajones's Avatar
I'd say not too much to worry about Pinion Head. There is very little parts breakage at the PS drags. Running on stock tires, you can still nab decent 60 foot times, but they aren't dumping the clutch at 5,000 rpm on sticky tires either, so transmission or driveshaft issues aren't as big of a concern. The tires become a nice cushion. There are tons of PS 4-speed cars of all makes having fun in that class. Lots of them making decent power and running well into the 12 and even 11 second zone.
Here's Jim's L88 Runs easy 11's with lots of tire spin
https://youtu.be/spnnrapgiSk
Here's Donny's little L79 with a stock M21. He's been pounding on the same transmission for at least 8 years, he's in the 12's cutting 1.7 60 foot times. He doesn't baby it either. Maybe you guys will enjoy this, he was paired up with a 67 RA bird for a best 2 out of 3 shootout. Or maybe not, it didn't fair too well for the bird, lol.
https://youtu.be/j6VTC-r9cKQ
Old 12-10-2017, 07:06 PM
This was the first carnage this fall..it lead to the tranny..or maybe it was the back u joint that caused everything??Damn Dave Bisschop....I should send him the bill!
Old 12-10-2017, 07:19 PM
JSPONT's Avatar
LOL, I went with billet yolk, and 1350 joints for that reason!!
Old 12-10-2017, 09:26 PM
64speed's Avatar
64speed 64speed is online now
Everyone thinks I’m crazy but everything I am doing to my car I am doing way overkill for my intentions just for the fact that I have learned the hard way that if the wrong thing let’s go at the wrong time it can take so much more with it. My 467 has all forged internals my 9 inch has 31 spline axles and will have a hellical locker. Beefed up pumpkin from strange or moser. 1350 u joints and billet yokes. T56 magnum says it has a 700 ft lb rating. We will see. I had a 64 gto with a stock 66 YS 389 and M20. Caught second one good time and snapped the points where the rear crossmember attach. Rearend pitched forward and broke the snout off the m20. Thousands of dollars later I realized pay now or later if you’re gonna “get on it” LOL
Old 12-10-2017, 09:54 PM
JSPONT's Avatar
I try and do the same depends on the bank book. My street car has 35 spline spool, motor has forged internals, I knew the tranny was the weak link, but for my h.p. it is hard to get a stick to hold up without spending 10g's. Going th 400 with some billet internals.
Old 12-11-2017, 08:20 AM
The Boss's Avatar
The Boss The Boss is offline
Nothing that bad on a Pontiac but I sheered the pinion on the front axle of my 2000 F350 trying to pull a fully loaded lumber truck out of the mud.
And go racin' in the street.
Old 12-11-2017, 08:27 AM
JSPONT's Avatar
DAMN!!!
Old 12-11-2017, 08:44 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Talking
POS Fords
Just kidding
Old 12-11-2017, 08:45 AM
Keith Seymore's Avatar
I have a small "broken parts" display at my desk.
Given the benefit of further thought - I should mention those are all Chevy parts.
K
Name:	broken parts 1.jpg
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 12-11-2017, 09:08 AM
mgarblik mgarblik is offline
I thought this was funny. Last year at a match race we running the nitro funny car of Bazz Young, a 69 Camaro with a Brad Anderson Hemi. He has a large table and a couple milk crates full of all kinds of mutilated hemi parts. Pistons, rods, valvetrain, typical nitro carnage. A 12-14 year old kid walks up and is looking over all the blown-up parts. He asks Bazz, "where did you get all these blown-up parts?". Bazz, with his Australian accent doesn't miss a beat. He points to the funny car and tells the kid, "I have a machine over there that makes them!". The nitro cars seem to make routine sacrifices to the aluminum gods.
Old 12-11-2017, 09:12 AM
The Boss's Avatar
Originally Posted by dhcarguy View Post
POS Fords
Just kidding
I got him out - cracked the center housing in two places on the Dana too.
Old 12-11-2017, 07:30 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
No good intentioned favor, goes unpunished!
Shut it off
Shut it off
