Old 09-11-2017, 05:42 PM
455Ron 455Ron is offline
Default What heater hose nipple?
I need to get a new hose nipple for my 6X heads. The catalogs​ show 2 styles. One is for up to '72 heads and had the spring. The other is for up to '77 or so with rubber inside. They are interchangeable, is there any advantage of one over the other?
TIA
Ron
The Following User Says Thank You to 455Ron For This Useful Post:
Old 09-11-2017, 05:49 PM
STEELCITYFIREBIRD's Avatar
I don't know, but am curious of the reason for the spring and/or rubber.
I had a 77 GP and it had decent heat only a block from the house on the coldest of days.
The Following User Says Thank You to STEELCITYFIREBIRD For This Useful Post:
Old 09-11-2017, 06:35 PM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
301 HHN has the built in right turn...
Old 09-11-2017, 10:04 PM
71 T/A 71 T/A is offline
455Ron, PM sent.
The Following User Says Thank You to 71 T/A For This Useful Post:
Old 09-12-2017, 06:11 AM
steve25 steve25 is offline
If you actually live in a area where you drive the car during a season where you need heat then the nipple with the spring helpsthe motor build heat faster.
