Old 08-29-2017, 11:36 AM
pontiac_boy pontiac_boy is offline
Default Oil pan recommendations
Im starting to collect parts for my stroker motor and I'm looking for opinions on oil pans. There motor is going to be going into a street/strip car that could see some higher RPMs. My builder said i would be fine with the Canton 15-400 but I've noticed a lot of people are running the canton road race 15-444. Just looking for opinions on which would be a better option for a car that'll see both the street and strip.
Old 08-29-2017, 11:56 AM
Formula8's Avatar
Formula8 Formula8 is offline
I have a used 15-450 that will be going up for sale soon if you are interesed PM me.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 08-29-2017, 12:02 PM
steve25 steve25 is offline
Do you need a pan for a A , B or F body car?
Old 08-29-2017, 03:09 PM
Steve C. Steve C. is offline
Be sure when you are evaluating the Canton products their listing is for "system capacity". For example the 15-450 is listed as '6 quart system capacity', by that they mean 5 quarts in the pan and 1 quart in the engine including filter. Most popular filters do not hold one quart.
Old information here:
Old 08-29-2017, 03:41 PM
It's going in an A body car. 1972 Lemans
Old 08-29-2017, 04:21 PM
ta man ta man is offline
The 15-400 is a nice pan with a single kick out on the drivers side.Clears everything well on a 1980 firebird and doesn't hang down too low.You will need a mini starter its tight.
