1969 350 block and matching heads, $1000
--1969 350 CID block, XS code, bored .030 over, professionally machined, balanced, blueprinted in 2003, Alum hyp pistons, cast original crank, cast rods, replaced bearings all around, freeze plugs
--#47 matching iron heads, also machined and reworked in 2003, including "stage 1" port and polish work --#7 cylinder had piston-to-valve contact, removed piston and rod (damaged). --Valve seats checked, cyl 1 and 7 need reseat --Selling short block to build new motor --Motor has ~20k miles on it --Motor made ~400HP with all high-perf goodies on it, before cylinder 7 issue --comes with Melling high volume oil pump, Comp cams hyd roller 228/232 profile w/ lifters, --pics soon $1K Must be able to pick up, unless you want to also pay for freight shipment charges. Contact me w/ any questions Moe
Once you go Pontiac, you never go back |
pics
Decided to keep cam and lifters.
New price: $800
NEW PRICE - $600!!
"...Alum hyp pistons..."
Looks to have TRW L2339 forged pistons. That's a good thing. So, are you saying that all this engine needs is a cam/lifters and head work ? Or is it just a core engine for a rebuild or refresh ? There's a Chino, CA guy lookin for a crate engine or just a block. I'll give him a link to this thread. If he's interested, I'll pass on the info or help him contact you. He's restoring a '74 Bird. But I assume the motor mount adapters will work for the '69 block. |
Ponyakr,
Sorry missed your response til now. YES, these are TRW forged pistons, not alum hyp as previously mentioned. My mistake. The motor needs a new piston and rod in cylinder 7, as well as cam /lifters + head work. She'll run with no head work, but cylinders 1 and 7 have leaky valves (i believe exhaust). I have an extra piston laying around that can be re-used to rebuild cyl 7, I can throw that in. So just need a new rod. Motor mounts should match right up, since they used Pontiac blocks on 74 Birds and their location didnt change i believe.
$500!!!
BUMP!!!
$300!!!
sold
