Ticket Machine!
How's this for Consistency in Time trials, all about a hour apart on my 275/60 ET SS Drag Radials
NICE!
What did/would you dial?
you shift that or is it a true automatic? Nice stack!
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I shift it, and I don't use my light i watch the tach!
Nice!
Nice
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
More impressed with your lights.
Well done Darby!
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Nice string.
I'd dial like you skip the thousandth crap. I use shift light as time to look at tach then click to gear exactly where I want. Last car it was about 200 rpm above light setting. Shift actual change was another 100 rpm from time I clicked shifter. |
I'd put you in the right lane! 😁
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
Lol!! How have u been Bill, Haven't seen ya at the rock in quite awhile!, been looking forward to lining up with ya
Very nice. Can you say anything about the carb, converter, the slicks, being the same as the Grandville?
What launch technique; off-idle, or load converter lightly, or trans-brake? |
1050 Dominator with Blp blocks, my emulsion setup, blp 16 hole boosters, blp 112 jets, UCC 9'' 5300 flash stall Converter, no slicks M/T ET SS Drag Radials, 19 lbs of air. leave at 2500 on the foot brake using a 2 step
My combo is so far behind because of "going low compression" it's not funny: rejetted 1050, 4000 stall Switch-Pitch, and 28"/15 ET Drags tending toward dryness. Dang, i need to bump it up.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
DAMN!!!
DragStarLeMans |
Wow that's impressive! You and the car are dialed in, you should go pro!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
