Old 07-26-2017, 06:06 AM
WARCHIEF400 WARCHIEF400 is offline
Default 1968-77 GTO/Lemans Parts
1968 Hurst Dual Gate Shifter $450.00
1968 Ram Air Carb #7028270 $1200.00
1968 Rear bumper brackets $75.00
1968 GTO Passenger door Glass with lower frame and bracket $50.00
1968-69 Lemans front bumper brackets $75.00
1968 Lemans front bumper black plastic insert $25.00
1968 Lemans front bumper grill brackets $25.00
1968-74 power brake booster $50.00
1968-72 GTO/Lemans lower main duct and vents $100.00
1968-72 Intermediate steering shaft $50.00
1968-72 Rear Windshields $80.00
1968-72 Coils $25.00
1964-79 Oil Filter housings $85.00 each
1968-72 front lower window reveal molding $60.00
1968-72 rear front upper fender chrome moldings $30.00 pr.
1968-71 Throttle cable $30.00
1968-71 Accelerator pedal & bracket $50.00
1965-78 Turbo 400 Transmission oil pans $50.00
1968-72 front suspension parts center link, tie rods etc $100.00
1968-72 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $150.00
1968-72 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1968-72 door vents pr. $20.00
1968-72 positive battery to starter heat shield tube,
1968-72 1/4 window glass chrome trim moldings $30.00 pr.
1968-72 window regulators set of 4 $150.00
1968-72 brake pedal assembly $75.00
1968-72 a/c compressor with main bracket $75.00
1968-72 Lower main duct with two vents $100.00
1968-72 emergency brake pedal and bracket $50.00
1968-72 rear license plate bracket and holder $35.00,
1968-72 front armrest bases parchment, black $25.00pr,
1968-72 door & 1/4 glass regulators $50.00
1968-72 water thermostat housings $15.00 ,
1968-72 door hinges $50.00
1968-72 points distributors no RA one left $80.00
1968-72 wiper transmission assembly (2) $75.00
1968-72 Green & Pewter Grey window lace
1968-72 rear windshields $80.00 no defrost units
1968-72 blower motors $25.00
1968-72 a/c inner boxes $150.00,
1968-72 headliner bows $50.00 set
1969 Water pump Date Code is Jan of 69 $50.00 with divider plate
1969-72 Power Front Disk Master Cylinder $45.00
1969-72 AM & FM RADIO PULLED OUT IN 1983 WORKS $475.00
1969-72 AM RADIO WORKS $200.00
1969 Stock 4 barrell intake manifold Date code C129 $125.00
1969-75 Harmonic balancer $50.00
1970 GTO Front Bumper prep by body man been off car for over 30 years $1500.00
1970-72 Doors rust in them $100.00 for pr.
1970 Quadrajet Carb in running Condition #7040263 $375.00
1970 GTO Front Bumper Grills $450.00 all tabs in place in very good condition
1970 GTO Front bumper to frame brackets $300.00
1970 GTO Front Headlight housing assemblies $250.00
1970 GTO Alternator bracket media blasted, primed and painted $80.00
11 Bolt Timing Cover $105.00
11 Bolt Timing Cover withy divider plate and pump $150.00
Full length windage trays 75.00
1970-72 Show Quality Front Window Stainless Moldings, Professionally Polished $275.00
1970-72 Rear Bumper brackets Professionally blasted, primed and painted $250.00
NOS A/C Delco PVC $9.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
NOS Three prong Thermo Switch for rally gauges $250.00,
1971 Water Pump with date code Feb of 1971 $50.00
1971 GTO Rear Taillight lenses $150.00 Each
1970-1972 Rear Taillight housings $50.00 Each
Rear wheel drum wheel cylinders $25.00 PR.,
*1972 Purge valve hard to come by $175.00
1972 Throttle cable, accelerator pedal and bracket and kick down switch $175.00
Water temp sending unit for rally gauges $40.00
Oil pressure sending units for rally gauges ,$45.00
NOS 1970-72 Wheel well moldings $850.00
1970-72 pair of used rear wheel molding $160.00
1972 Pewter grey door pull straps $80.00
1971-74 alternator bracket for non p/s $50.00
1969-72 Goldenrod/Tan & Pewter/Gray PEWTER steering wheels crack free $125.00
1969-72 auto shifters $130.00
Fuel escentrics $35.00
1969-72 harmonic balancer off low mileage car $50.00,
flexplates $35.00
1970-72 inside glove box liner $45.00
1969-72 Gauge & Speedometer cluster $65.00
1970-72 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00
assorted stainless moldings,
1971-72 miscellaneous duct work
1970-72 driver side lower black dash metal trim $45.00
1970-72 ac & heater dash control with cable $135.00,
1969-72 radio rear support bracket $25.00
1968-72 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
valley pan $65.00
1970-72 door glass $100.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
TCS Switch $75.00
1970-72 pillar post covers $45.00
1971-74 New Power Steering Pump $90.00
1971-79 used power steering pump $45.00
1971-77 Alternator bracket $50.00
1971-72 front fender side markers lenes,frames and bracket clips $90.00 without frame brackets $50.00
1971-72 GTO FRONT ENDURA BUMPERS WITH FRAME TO BUMPER BRACKETS AND CENTER SUPPORT BRACKET $500.00,
1972 GTO GRILLS $300.00
1972 GTO SEAT BELTS complete $250.00,
1971-72 GTO Headlight assemblies $350.00
1971-72 GTO HEADLIGHT TRIM MOLDINGS $125.00
1971-72 GTO ENDURA BUMPER TO FRAME BRACKETS $150.00,
1971-72 GTO Headlight assembly brackets $100.00
1971-72 GTO front center support bracket $100.00
1971-72 GTO Complete hood latch assembly to core support $200.00
1971-72 GTO headlight & parking light wiring harness $75.00
1971-72 Engine wiring harness for 400 with auto and ac $50.00
BLUE VALVE COVER OIL CAP $25.00 VERY NICE
NON A/C HEATER HOSE BRACKET $25.00
Pontiac oil pan $65.00
1972 front parking bezel $30.00
1971-72 ALTERNATOR/POWER STEERING BRACKET $50.00
1973-74 ERG Valve and Bracket $35.00
1976-79 Harmonic balancer $50.00
a set MALLORY 7MM SUPPRESSION SPARK PLUG WIRES points type $25.00,
AFTERMARKET FLEX FAN $15.00,
new points and condensers
temallory@msn.com __________________
Timmy Mallory
Timmy Mallory
Old 12-01-2023, 11:02 PM
moparcolt's Avatar
moparcolt moparcolt is offline
Do you still have the 7028270 quadrajet?
Sent from my SM-G973U using Tapatalk
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
