Rear tire fitment
What's the biggest rear wheel and tire combo you can fit underneath a 65 Tempest with a frame pinch and minor work to the wheel housings
I got a 29-15x11 on a 10" wheel to work. It required "flattening" the frame, cutting the fender lip, and cutting out some of the inner fender panel. Different manufacturers have slightly different sizes. The Hoosier was a little wider than the Goodyear. I'll look for some pictures tomorrow.
I had a 15x8 with 4.5" BS with a 275-60 drag radial on mine with no cutting or trimming.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
I have a '69 12-bolt in mine and Hoosier QTPs that were 28x11.5x15 with a 5" BS no cutting.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
That's what I have on mine. Still enough clearance for street driving also.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
I also have a 69 12 bolt,8 inch wheel 5.5 backspace, and 275/60 Mt drag radials. Barely... You'll find out if your housing/frame/body is centered for sure...
'65 Tempest 467 3650# 11.30@120.31 |
The car has 69 12 bolt in it now..I have a 275 on it.Im putting a a trz fab 9 done to stock 65 length.I would like to get a 10.5 w under it but i would probably need a mini tub an have to move the shock mounts.I want to put a HNR parts bar on it.
I have that bar on mine. Roughly speaking, the frame rails will interfere before the bar will, but not by a lot...
I think i can make a 295 60 work.With a little work.The HNR bars are nice an simple an they work
A 10.5W will not fit unless you do a full tub. Mine is mini-tubbed and clearanced inside. A friend thought his 10.5W would fit, so he brought it over. It would not even go under the car. It hit on both sides.
Thanks old man taylor.If you get a chance post some pics up.I would like to see your car
I'm not sure what kind of pictures you want, so here are a couple.
Thanks old man Taylor
