It seems I'm not going to get the original tri power back for my 66 GTO.
So I see set ups for sale with both cast iron and aluminum intakes, they say both are original. which would a 66 have come with? or can you know? |
Cast iron only, no factory aluminum Tri-Power intakes were produced with the exception of 1961 Super Duty intakes.
An aftermarket aluminum 1966 Tri-Power intake is being produced, but again they were never available from the factory. Some intake identification pictures and info:http://forums.maxperformanceinc.com/...d.php?t=786314
There were not any factory Pontiac tri-power intakes sold to the general car buying public made of aluminum
The repop in aluminum is the same as the OEM cast iron version just in aluminum. Some like to buy that one and then paint it so you can't tell the difference but shed a few pounds by doing so. If you can use your original block and heads then you might want to hunt down an original cast iron to get the date correct.
Thanks guys. I might see if I an find a date correct intake, maybe I can use it for the restored tri power set ups I see for sale and they can just credit me the intake core fee.
On that, they say these are new carbs on the restored set ups, but I assume new means rebuilt? there are no " new " carbs are there ? |
![]() Quote:
The exception might be a carb from Jon Hargrove in Missouri that acquired some NOS stock years ago but he typically want $$$$ for his stuff. Tom V.
I would run, not walk, from anyone selling an original 1966 aluminum tripower with new carbs!
There are a number of reputable people in the Pontiac hobby, some that post and advertise here, that could sell you a rebuilt or restored 1966 original cast iron tripower with rebuilt or restored carbs. Some also sell the reproduction aluminum tripowers with rebuilt or restored carbs. To my knowledge, the only new Rochester tripower carbs are new old stock (yes Tom, I still have a few that I have kept to settle arguments). There ARE new reproduction Stromberg 97's (type EE-1), and Holley 94's (type AA-1). Both are smaller than the Rochesters with a 3-bolt base instead of 4-bolt. Jon.
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
![]() Quote:
I'll keep my eyes open for a 66 setup! ![]()
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
I have a Aluminum Intake (one of the early repos it think) and it doesn't fit worth a damn.. I'm not sure if the newer run ones fit better but the port match isn't the only problem(and the port match is very very bad). I could not for extensive work make the bolt holes line up and went thru on the water port on the fronts. Had to use studs on front two even with extensive grinding to make fit. So my vote is the aluminum manifold is junk and I would stay away from unless they've changed the mold.
![]() Quote:
1st Gen Aluminum Tri-Power Pictures (attached). Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 08-15-2017 at 09:45 PM. |
I bought the 66 alum repop from Parts Place and it fit perfectly.
Glad you got a good one, some of the later ones had bad core shift issues.
Tom V.
