Hi everyone. I checked in my assembly manual for how to attach the rocker panel moldings to the rocker panel clips, on my '71 GTO. I didn't find anything. The moldings seemed loose and when I looked underneath, the bottom was only attached to 2-3 of the clips. All of the clips are there. I took them off and they cleaned up very nicely. I'm going to put these back on tomorrow, but I'm unsure if you should hook the top and snap in the bottom, or vice-versa. Looks like it could go either way. I'm really not sure. Any suggestions would be very helpful. Thank you, Carmine.
first clip the lower brackets into the trim 2 ea side
hang the trim on the car.. over the clips mounted.. sometimes you need to tap the tops in a tad to snug the fit up against the body center it and look for the phillips screw holes for alignment bolt the lowers to the rocker 5/16 headed screws put the phillips screws in the ends that should getcha close Scott |
![]() Quote:
http://www.tamrazsparts.com/68-72-gt...-clip-set-new/
are you missing the long ones in the picture ?? they clip into the trim bottom edge and go under the car and get held inplace... |
![]() Quote:
yes that would cause them to be flappy
I have 4 for 25 shipped if you want em Scott |
Oops, sorry Scott. I had no idea you had any. I just ordered a complete new set from Ames, Carmine.
its nice to have good clean s tuff and new hardware ...
glad you figured it out before you bent your trim Scott |
