Pontiac - Street No question too basic here! |
View Poll Results: Which Engine for My New Build and Why | |||
440 | 9 | 16.67% | |
455 | 33 | 61.11% | |
Other | 12 | 22.22% | |
Voters: 54. You may not vote on this poll |
Poll: 455, 440, Other
Ok, so my stock 455 ingested some paper that apparently was hiding inside and ended up damaging it due to oil starvation.
http://forums.maxperformanceinc.com/...d.php?t=806506 This poll is to ask what I should build and the pros and cons associated with each: 440, 455, or Other The car is a '70 LeMans with a TH400 and 3.08s. It is a street cruiser and will see highway time and no strip time. I just want a fun motor that has power but great manners because it will get its AC hooked up as well. I have a 428 crank as well as the 455 so I was considering building the 440. Of course a 455 represents the "no replacement for displacement" category but I'd like some input.
The More People I Meet, The More I Love My Dogs! Last edited by ponchjoe; 06-21-2017 at 10:12 PM. |
For tall 3.08 gears and a "fun cruiser" you can't beat a 455.
The only reason to de-stroke and build a 440 is because, like me, you're weird and want to do something a little different and maybe try to turn some stupid high RPMs. That doesn't seem to fit your goals, so stick with the 455. You need torque and there really is no replacement for displacement where that's concerned.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
What Will said. 440 for a screamer with low gears, 455 for a cruiser with high gears.
It's real simple, if the car is over 3600 lbs with you in it go with the 455, it's power band with stock iron heads , a Cam of 225 duration @ .050" will be 2400 to 5000 rpm with 3.08 gears is great!
Go with the 455.. As long as you are grinding the crank anyway, have them do an offset grind to BBC journal size and pick up a little extra stroke. If this is just a cruiser, no need to stress the internals with a bunch of rpm. You will have plenty of power and the engine will live a long life.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
I am a little weird as Will suggested and the car does have some 3:73s in it currently but was planning on a change to make it more highway friendly
The More People I Meet, The More I Love My Dogs! |
Does the car have a posi rear now?
With whatever you build for street only usage , even if it was just a 389 those 3.73s need to go anyway!
Agreed. It's fun from stop light to stop light though
455 for that application.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
You already have the 455 so it makes the question easy for me, Build the 455
If you were starting from scratch and had nothing I might suggest something different. |
To the gentlemen that said other I'd like to hear your thoughts
If you don't boil the tires up now stop light to stop light the TQ of a stock 455 with 3.73 gears in the back then it needs to hone thru anyway!
Other
400 is the gold standard IMO.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
B&P, would you elaborate please?
455 if you don't want to change your gear ratio.
I was just reading an old H-O performance parts catalog where the section with the best all-around combination was written. I miss those guys and wished that I had purchased a few more items when I had the chance. |
455........What heads are you running currently?
What the budget? Any room for port work & bump up the compression a little......might be the best bang for the buck!! |
