Hi everyone. My rear deck lid spoiler arrived yesterday from Ames. Removed it from the box. Holy crap is that thing big. Like an airplane propeller. Wide and long. Almost looks like it's longer then the width of the car. Like it will hang over, but I'm sure it won't. Previously, bought a rattle can of paint for the spoiler. Not sure what I was thinking. That can will never do it. Will probably have to buy a quart can with the mixers. Directions for install seem simple enough. Should be fun, Carmine.
I do a lot with a rattle can, but wouldn't recommend attempting to paint a piece this big or prominent with one. In addition, I would bet it will need a little work to get it nice and flat. Take it to a body shop and pay a professional.
Carmine,
Here is a photo of my rear spoiler installed. It is pretty big( some call them ironing boards). I would not try to rattle-can paint this piece. Recommend fitting the spoiler first, then painting after drilling the mounting holes. Quote:
![]() Quote:
No, no rattle can. I agree. Too much area to cover. Going to have to buy a quart of paint plus whatever else is need. I have some etching primer left over and I'll use that also. I'm not sure what this is made from, I'm assuming fiberglass, and it appears to be very straight and flat. Regardless, I'll still block sand it. I also prefer single stage paint and that's what I'll go with, Carmine. |
Thank you.
BTW, my car did not come from the factory with the spoiler and they are heavy. Unfortunately no source that I am aware of reproduces the larger diameter/ size spring to help hold the trunk lid up after spoiler install. Mine does stay up O.K. but just be aware of the extra weight. Quote:
![]() Quote:
But you should be able to change the position of the tension rod to accomodate for the weight of the newly added spoiler.
![]() Quote:
Be sure to get the right locations for the holes - certain things you only get to do once.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
![]() Quote:
Thanks for those pics. At first I didn't see where the 4 bolts come through, but I do now. The area looks to be fairly flat. |
Paint needs to be color matched and of the same "type" as what's on the car, if the car is base/clear then base/clear for the spoiler to get close to matching. That green is not an easy color to match when painting. Fortunately, since it's a spoiler it'll match the rest of the car easier then say if you were trying to do a qtr or a door.
