Squirter plate....
The closer the fuel is to a vapor the better upon entering the motor!
On motors that are not FI and who's on the fat side average BSFC numbers can not be made be leaner with dropping off top end hp , this looks like a improvement can be had!
We disconnected the secondary accelerater pump on our crate motor 650 HP carb and noticed no slight stumble coming off the corner. At 4500 rpm there is was no need for the extra fuel I suspect this would work and like my buddy says he'd spend $40 to watch monkeys F#@^..
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
Could this be a cure for the infamous "Edel-bog" from the non-AVS (AFB) carbs?. Anyone willing to give it a try?
after initially thinking to give it a try, i decided it was too much money for what it is.
If you have the free time it's darn easy to get some .020" Brass sheet and snip, bend and solder one up!
Anyone have a 3 D printer?
If I had one in my hand, I would pound it flat, put it in my flatbed scanner, import it into AutoCAD with a 1:1 ratio, trace it, generate a DXF file, import that into emachineshop software ... could probably have them die cut, or laser cut in volume for about $1 - 2 each ... make a jig to bend them .... viola, probably $3 each
