Old 05-27-2017, 10:51 AM
track73 track73 is offline
Default "O" rings.
I recently installed a new hose from the compressor to the new receiver dryer. I had to un do a couple hoses to get the job done. I didn't notice any rubber "O" rings when I unhooked the lines. I pulled avacuum and there is a leak. I will put some dye in and check for leaks but I was wondering about the absence of "O" rings. I suspect there may be a leak at the compressor since it is 38 years old, but it worked before I changed the engine. While changing the engine and putting the compressor aside, the hose kinked at the compressor causing small hole in the aluminum pipe. The car is a '79 Trans Am.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 05-27-2017, 02:19 PM
Pepi's Avatar
Pepi Pepi is offline
Should be o-rings. Are you sure they didn't fall off/out when disconnecting the hoses. Hole in pipe would cause leak also.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 05-27-2017, 03:20 PM
i need an eploded view of the parts of my AC hoses and associated parts. Where can I get one?
flat pistons
RPM rods
w 2.73 rear gear
