Advice Request for Front End Suspension Rebuild - 71 T/A
Good evening,
I'm planning to have the front end suspension on my 1971 Trans Am rebuilt by a mechanic friend of mine, and to save a bit on the cost, I would like to source the parts myself. However, my knowledge in this area (and in mechanics in general) is very limited, so I'm seeking advice on this forum as to where I can find quality after-market parts to use in rebuilding my car's front end suspension in as close to original stock configuration (ride height, performance, etc.) as possible. Could I please get some guidance on where I should go to get the best parts available, perhaps in the form of a parts kit, if possible? Any thoughts would be greatly appreciated. Thank you very much for your time! CEB |
I bought all my front end parts from PTFB pro touring F body. His prices are reasonable and good quality. I ended up adding stuff like upper and lower tube control arms, comp suspension, rear discs etc. If you want stock ride height and changing the springs and shocks the GT or GT pro kit is what you want to go with. The comp kit is stiffer and sits a little higher in the back and is more geared for racing..
http://www.pro-touringf-body.com/cha...omponents.html
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes. https://www.facebook.com/media/set/?...7567172&type=3 Last edited by niceta; 05-21-2017 at 09:14 PM. |
Helpful info, niceta. Thanks for your time!
Many people get Energy suspension bushings. Key to any of this is to make sure it all moves, so it works, has a Load on it , BEFORE you snug it up. Good luck!
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
If you're looking for something close to stock performance, make sure you get proper rubber bushings, and not polyurethane.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
