There's a back-and-forth on roots superchargers in another thread. Thought I should start a new thread. The discussion was about efficiency which made me recall a fun fact.
The John Force organization owns somewhere between 30 and 60 blowers. They run each one once and then set it aside to restrip it. That way, they have as near as possible exactly the same efficiency every run. I can say from experience that they are very tight when freshly restripped, but loosen up with use. Since we don't have the JFR budget, we base our tuneup on the looser, broken-in condition and don't restrip unless we have to. Eric
Very interesting.
Good thread, every blower is not created equally theres teflon strip blowers......non-teflon stripped blower, 60 degree helix rotor blowers, 120 degree helix rotor blowers.....etc. some of the pros have dynos just for the blowers......there's a reason!
GTO George Last edited by GTOGEORGE; 03-21-2017 at 10:43 PM. |
Both of our blowers have been on the blower dyno at SSI in Cleveland. Great company to deal with.
Eric
The fact that John Force KNOWS that the efficiency changes after every run tells you that he knows you can't predict supercharger efficiency accurately from run to run, much less over a season of runs. Something the Blower manufacturers have known for years.
Eaton, Whipple, Lysholm, will all tell you the same thing. They give you a ball park number. Despite what some assume. Tom V.
![]() Quote:
GTO George |
![]() Quote:
Jm
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
![]() Quote:
I don't notice any wear on my blower through out the year, still can't get my egt numbers down but everything seems to be working ok. GTO GEORGE |
![]() Quote:
Even with methanol fuel, you have no clue how to control the combustion temperatures in the engine. You are too hard headed to listen to me. Why don't you call Travis Quillen at Quillen Motorsports and have HIM explain to you how it works, George, with methanol and egts. Travis is an outstanding tuner. Tom V.
![]() Quote:
GTO George |
SSI 14-71, standard helix. We bought refurbished used ones so they don't have any of the gee-whiz latest stuff. Just ordinary old school stuff in great condition.
Eric
![]() Quote:
Why not a High Helix one with 120 degree rooters? GTO George |
One of our advisors a long time ago told us that nitro and high-helix don't play well together. We haven't investigated further to know if that was accurate or an old racer's tale. Turns out that the standard helix was readily available on the used market and we have a good tuneup now based on std. helix. So no changing now.
Eric
![]() Quote:
Thanks! GTO George |
Are you switching to high helix? Why not just run your existing one a little faster?
Eric
![]() Quote:
I'm about 27 over right now. Haven't decided what I'm doing yet, tossing some ideas around. GTO George |
![]() Quote:
Jim
![]() Quote:
Ya I know..........probably go quicker too BUT its always a money thing! GTO George |
If you're fueling adequately with carbs at your current OD I'd be surprised if you went faster with injection. If you step up the blower I think you'll find the injection to more reliably provide the fuel needed.
The secret to happiness is not getting what you want but rather, wanting what you have. |
![]() Quote:
