Lets discuss motor mounts
Hey guys. I'm having PaulK here build me a 434 {4" stroke 400} to autoX and road race in my 1967 GTO. The car is a street car primarily but its going to get hammered on pretty good 4-6 times a year. I'm wondering what my options are for motor mounts. Can I get away with stock mounts and just make a strap from the frame to the driver cylinder head? Or will I need some kind of aftermarket mount? I was told Jim hand had some kind of stock mount modification. So what are my options? At what power levels do I need to step up?
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Some people have experienced issues with fitment, by I love my Butler poly mounts. They bolted right in on my 69.
http://butlerperformance.com/i-24452...tegory:1234745
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
You will be fine with stock mounts and a chain or strap to the drivers side head. Until last season I ran with a bracket bolted to the head with a chain attached to it and the other end was attached to the frame. I was at 800hp. Never had a problem with it, beating on it nearly every weekend for 24 years. I think I did change the mounts once in that time period. Last year I finally switched to a front motor plate.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
I'd go with the Poly mount on the engine and tranny, road racing you're going to get some big time wheel hop from time to time downshifting, so with up and down shifting you'll eventually overstress the rubber mounts.
Worth the extra costs up front.
https://www.facebook.com/Outlaw-Vint...7899333725868/ |
I'd suppose doing same thing on other side wouldnt be a bad idea if you did alot of hard down shifting with a stick car. |
ho428, is that what you are running for motor mounts? I plan on doing the same thing as Nick but with my 70 T/A and will have a similar motor build once completed.
Nick, excited to see your build come together, should be quite the package once completed!
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15. 1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-( 1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-( |
