Valve Springs for solid roller
Looking for recommendations on valve springs.
Lobes 4253B (intake) and 4214B (exhaust) Both .440 lobe lift (cam card actually says .441) Card is attached Running this in a 535 with first gen E-heads ported to approx 335 intake cfm at .700 lift. Race engine. Rpm range will be wherever it stops making power I reckon. I assume 7000-7500 range?
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge Last edited by PontiacMatt72; 01-23-2017 at 12:54 PM. |
need valve installed height with retainers and the keepers you are going to use to narrow down the choices, and rocker ratio
Open to suggestions on that (installed height, etc) as well... probably going to get all new valves.
Using Harland sharp 1.65 rockers with stud girdle
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Very similar to the cam Tony Bischoff used for my fathers 571, also with 1st gen round port E-heads.
Tony used 943-16 springs installed at 1.915" with 240 lbs. seat pressure. He uses Harland Sharp 1.65's as well. Here's the cam card. Last edited by Formulajones; 05-15-2017 at 10:28 AM. |
We usually use atleast 240 seat and 700 open with those lobes. I hope you're using the HD Harland Sharp rockers.
PAC 1289, That's what I'm using, they were 255@2.00 /640@.745 new tested
https://www.racingsprings.com/1200-S...-1243/Item/239
PAC 1243 Same as Comp 943 spring. 240 at 1.900" Both Dave Crower with a custom sold roller with .4250" lobe lift (260 @.050) and John at Bullet Racing Cams recommended the PAC 1243 spring for my Ultradyne MSD solid roller with .4300" lobe lift and 255 @.050. Both with 1.65 rocker ratio. .
My comp cam sr is 280/284 with .440 lobes . Using comp 944 springs.
190@1.950 747@1.200 HS 1.5 rockers with girdle for d ports
Illinois Outlaw Gassers 6.27@107 9.97@131 Last edited by Bill Eveland; 01-23-2017 at 06:21 PM. |
I currently have a set of "originals", but if they aren't up to the task, I have no problem upgrading to a set of "HD's".
Probably deserves its own thread... (Rocker Arms). I'll do a search first.
I'm using Pac 1225's. They are 250 @ 2.00 installed height. If I remember right my installed height is 1.95"
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Is there a spring graph available for the pac .need .600 lift spring load
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
I run the comp 944 springs as well. .646 and .648 lift solid roller
My choice would be to go with a set of Crowers anyway. |
My 2 cents.... Get you some valves that are tall enough to give you a 2.100 installed height.That way you have room to grow to a valve lift your comfortable with,then once you have run a year or two with that lift trouble free your able to add more rocker ratio or more lobe lift and rocker ratio to quote "turn it up" a bit. But you will most deff already spent the money once on a good set of valves! Also there are a ton of great 2.100 installed height springs out there to get you the spring psi you desire. ...... Room to grow....that was always my thing when I ran Pontiac stuff unfortunately some folks never understood that because they never raced in this century.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23 |
