OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-23-2017, 11:40 AM
scooter1966 scooter1966 is offline
Default Water pump replacement
Has anyone replaced their water pump without removing the timing belt?
Are there any issues with the belt getting water/coolant on it when replacing?
Jon Peters
66 tempest 3880 lbs with driver
455 .40 over, 6x, XE274H cam, th350,9 inch 3.89, 275/50/15 mt dr
13.04 et / 102.51 mph 11.97 et/ 113.68 mph w/150shot
75 Astre
Turbocharged OHC 6, TH350
1/8 mile stats 8.4813 ET / 82.07 MPH
Old 01-23-2017, 12:00 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
just clean off the belt before you put it back together I have had belts soaked in oil and just cleaned them off with some brake clean. these belts are pretty sturdy
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 01-23-2017, 12:06 PM
thanks.
that's what i wanted to hear
Jon Peters
75 Astre
Old 01-23-2017, 02:24 PM
Not that Difficult, just have to remove the rear belt cover that is held on with the front 2 accessory drive bolts. Done it many times. As GTOWAGON has said just clean off any coolant that gets on the belt.
Old 01-24-2017, 08:06 AM
Jeff Hamlin's Avatar
The belts are very well over engineered.
Pontiac brass was not keen on the use of a belt,
thus why so many test prior to production were conducted.
Many years back I was fortunate to communicate with Bill Knafel and he shared some insight about the extreme testing his team conducted.
His results along with the in house engineering test are what sold PMD to go forward.
They can outlast most engines if kept away from long term UV and oil exposure and/or physical damages.
More than once I have re-used belts in the past.
Old 01-24-2017, 06:04 PM
george kujanski's Avatar
Changed one at 100K just because.......
George
Old 01-25-2017, 06:59 AM
Just a heads up for anyone looking.
Belts are in very limited availability, as are water pumps.
Rock Auto offers a rebuild service,
I would think with a little searching a re-builder could be found in your area.
Old 01-25-2017, 10:55 AM
Looks like Flowkooler lists pumps also, pics appear to be a different pump, but i would think the impeller is the same, so they should be able to rebuild them.
http://www.flowkoolerwaterpumps.com/...578f699a690bfe
what is considered long term UV exposure as i'm not running the belt cover at this time?
Jon Peters
75 Astre
Old 01-25-2017, 06:59 PM
All the pumps shown/listed on the FK link appear to be Chevy 230/250 IL 6 (Pre 66 and post 69 OHC)
Long term UV exposure on anything rubber turns brown/chalky which leads to micro cracking. IMO one would have be exposed to sunlight repeatedly for sometime before I think it would be an issue.
As long as one is not driving around with their hood off all summer it should be good
Old 01-25-2017, 07:35 PM
tinindian68's Avatar
tinindian68 tinindian68 is offline
I was able to buy both 66-8 and a 69 OHC water pump from Rock Auto. They were around $40 each.
Old 01-26-2017, 07:34 AM
That's good news.
Less then a month ago when I checked inventory they were only offering rebuild service. Now if only correct starters would turn up.
Old 02-03-2017, 08:36 PM
maxepr maxepr is offline
Still on original belt and W/P 95,000 and counting.... I actually lifted a 350 engine with an old belt just to see how strong it was... Darn thing didn't break..
69 Trans AM RAIII Auto
69 Firebird 350 HO 4spd Black survivor
Old 02-11-2017, 12:56 PM
pontiacs-r-us's Avatar
pontiacs-r-us pontiacs-r-us is offline
I need to look into the water pumps also.I got one thru local parts store awhile back,& its leaking? Not sure how reliable these rebuilds are going be? Also I bought a new belt thru Kanter a few yrs back.Might still be available thru them?
