Tri-Power Tech 57-66 Tri-Power Talk
Old 12-30-2016, 03:27 PM
Dick Boneske's Avatar
Default '57 Tripower End Carb Wanted
Does anyone have a Rochester Tripower end carb from a '57 or '58 Pontiac setup to sell? I believe a Chevrolet end carb from '58 or '59 would work as well. Also, '57/'58 Olds J2 end carbs are the same as Pontiacs.
I could use just the airhorn or a complete carb to complete a '57 setup I'm building. I've attached a picture of a fairly original '57 setup to show you what the end carbs look like.
Thanks.
Name:	'57 Tripower I.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-31-2016, 10:07 PM
If anyone has an airhorn, complete end carb, or any '57/'58 Tripower parts, please contact me.
BONESTOCK GOATS
Old 01-01-2017, 12:09 PM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
These are not end carbs, but the pics show the tops of two carbs that I have. They appear to be from that era. One is complete, the other has no base.
Let me know if they are useful.
Les
ID:	443749   Click image for larger version
Old 01-01-2017, 08:29 PM
They are much better than what I have. I would have no problem with blocking off the choke shaft holes, but the vent is not so simple. I guess I could leave the one as is--I have another mushroom cover for the one that has it missing.
BONESTOCK GOATS
Old 01-03-2017, 11:57 AM
Pontiac62's Avatar
Dick, PM sent.
Les
Old 01-10-2017, 02:05 AM
dracowizard's Avatar
dracowizard dracowizard is offline
Default to identify
I have a J2 setup i believe and i thought if ok,if i posted a couple of pics if i could ask someone to confirm so i know what to asdk for the setup as i'll never use them.Don't mean to jack the thread,but appreciate if someones willing to take a look. Thanks,DeWayne
Gotta Luv some old Muscle..
64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror
3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna
Silvermist w/BlackVinyl Top
http://s161.photobucket.com/albums/t201/dracowizard/65/
Old 01-13-2017, 12:18 AM
Can you post some pictures of the setup? I would be interested if the price is right. They have the same carbs as Pontiac used in '57/'58.
BONESTOCK GOATS
Old 01-13-2017, 12:30 AM
Default glad too
Will do Dick,you've been a wealth of info on this site so i'll work with you.Be fri afternoon or so if ok,those are in my shed and once i get off tomorrow i will do some pics.I'll pm you my cell if you wish so you can text/call me sometime and i will get back to you after i get in Friday. Thanks,DeWayne
Old 01-13-2017, 07:25 PM
Default sum pics
Dick,hope these help - 1st set
ID:	444805   Click image for larger version
ID:	444806   Click image for larger version
ID:	444807   Click image for larger version
Old 01-13-2017, 07:29 PM
Default pics
2nd set
ID:	444809   Click image for larger version
ID:	444810   Click image for larger version
ID:	444811   Click image for larger version
Old 01-13-2017, 07:32 PM
Default pics
3rd set
ID:	444813   Click image for larger version
ID:	444814   Click image for larger version
Old 01-13-2017, 07:34 PM
Default pics
last ones
ID:	444816   Click image for larger version
ID:	444817   Click image for larger version
