Old 11-13-2016, 12:29 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Default My Ventura is getting a Butler 467
I bought this engine from a longtime friend yesterday. A 467 with fuel injection with a 4L80e Trans seems too fancy of a engine ( like a tux on a homeless guy) for my car.
Old 11-13-2016, 05:42 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Cool.
What are the details on the engine?
What Ecm are you using?
Old 11-14-2016, 04:09 PM
Rob B's Avatar
Rob B Rob B is offline
Homeless guys are allowed to have Tux's too!!!
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 12-14-2016, 02:48 PM
Me Notyou's Avatar
Me Notyou Me Notyou is offline
Sweet lets see a pic of the car too ! ( if you've previously posted one my apologies )
Denn die toten reiten schnell
More doors = more love!
Old 12-14-2016, 10:48 PM
It run 7.90s in the 1/8 on the redlines with a basically stock 455.
ID:	442722   Click image for larger version
Old 02-09-2017, 04:32 AM
brut4s's Avatar
brut4s brut4s is offline
Updates?
Old 02-13-2017, 10:36 PM
Originally Posted by brut4s View Post
Updates?
Nothing to update yet. I working on my T-37 right now and then the engine change for the Ventura.
Old 02-15-2017, 01:41 PM
SD455DJ SD455DJ is offline
se428bandit, I really like your '72 Ventura and '71 T-37 post coupe...nice cars. The sleeper aspect of the Ventura with the factory look is awesome.
Dennis
Old 04-17-2017, 11:00 PM
Well after some obstacles (column shifter, 6al box, finding the correct electric fans, radiator) it's finally running, so I drove it to the muffler shop, again. Hooker and Mad dog headers aren't the same length. Next is to figure out which WFO air cleaner will work.
ID:	452388   Click image for larger version
Old 04-18-2017, 07:39 AM
ponjohn's Avatar
Are you running 2 different headers?
Old 04-19-2017, 05:12 PM
mrrat1 mrrat1 is offline
He had to switch headers from D to O port with the engine swap....nice cars BTW
Old 06-13-2017, 10:34 PM
I went from 6X heads to Edelbrocks with the new engine. I finally got to drive it today without fuel issue and distributor problems, it's going to be fun. It will smoke the tires at 40 mph in second gear.
Old 08-15-2017, 08:47 AM
Slick's Avatar
Slick Slick is offline
If I may ask, do any of the round port headers work with column shift?
I may need to put round port headers on a 74 X body with column shift.
What should I know? Really like to use a 2" primary if possible.
Thanks,
Stuart
Old 08-15-2017, 04:20 PM
Rob B's Avatar
Thanks,
Stuart
Probably aint gonna happen without moving the tube(s). Don't even think you can get one remotely in place. You need that area to position the front of the header in place. 2" is a big tube to maneuver.
Old 08-15-2017, 04:36 PM
Slick's Avatar
Thanks,
What header (brand, etc.) would you suggest as a starting point? I'm pretty sure I'll need the largest practical primary diameter.
Stuart
Old 09-20-2017, 03:11 PM
Thanks,
Stuart
I used mad dog headers and I had to use a Lokar kit in order to keep it column shift. https://www.summitracing.com/parts/l...4/applications
Old 09-20-2017, 03:14 PM
Slick, if you use D-port heads, I also had Hooker Super comp headers and had no issues using the original column shifter.
Old 09-20-2017, 03:37 PM
Slick's Avatar
Thank you very much Mr. se428bandit!
That Lokar cable is exactly what I'll need!
My heads are round port, so the Hooker SC won't work.
I've heard that the Doug's headers for round ports fit very well, but I guess the 1-7/8" tube is a compromise I'll have to live with. Engine probably wants 2.125, I know that ain't happening. But had some hopes that 2" might fit.
Thanks again!
Stuart
Old 09-20-2017, 04:13 PM
Thanks again!
Stuart
The only thing about that Lokar kit and I had to worked on it about hour to get where everything worked correctly. The thing a liked about the Mad Dog headers are that they come apart so they were easy to install.
Old 09-20-2017, 04:17 PM
Slick's Avatar
Where to go to buy the Mad Dog headers? Are they round port?
Can't find them on their site, and Butler doesn't list any for either 67-69 Firebird or X Body.
Stuart
