My new best
Well out to the track today with Torquewar and drag radials bolted on set to 18lbs
Hit some 12:40 to 12:50... Then couple more burnouts and runs 12:28 @110.55, then a 12:25 @110.05. Pretty happy about the car was a great day....not sure how much more is left in it but I'm good with those runs. That's Torquewars car #4 we pretty much raced each other all day,,,,there was very few cars...had the look of rain for the day but held off but we had some wind in our face.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 10-29-2016 at 03:23 PM. |
Very nice! Congrats on the new best. What tires u running??
1969 Camaro 491 BBC/TH400/GV OD/3.50 |
Thanks those are actually a set I borrowed from Torquewar ....Hoosier 275/65/15
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Good job!
That's awesome man. I've really been itching to hit the track lately. Haven't been to one in years.
Those are Canadian time slips......so a 12.00 is really a 12.25..... lol ...nice runs !
Nice!
Friday night drags at Wild Horse Pass on the 11th. I hope you guys realize what you're doing to me here....
Get out there man......
I can really come up with a reason not to be there unless I hurt the car before then. I'm running on a mediocre engine and it's strictly motor so whatever it is it is. I'll man up and post a slip.
That's great Chris! Sounds like you're dialing it well!
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
Have you had a chance to put a wide-band on it to check a/f ratio?
Played with the timing at the track? Played with shift points? Light weight wheels n tires? I think you have some 11.9's in with a bit more test n tuning
As much as I don't feel like heading out tonight I think I can round up some co-conspirators for my date with destiny on the 11th.
That's great to hear as my combo is almost the exact same except I am using a RPM intake. Same head flow, cam, solid roller rockers and almost the same exhaust. I can't wait to get to the track and seeing you in the low 12's is a big boost since my build has been dragging on. Great numbers and good for you to be out at the track getting it done.
Chris
awesome and congratulations
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
You did awesome! You, Andy & TA Man are a couple Diehards! Gotta love it! Can you post up pics of your car & how your set up under the hood? Jeff
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Thanks Will.....I really haven't done anything to the car it's been weather and track prep ....I ran 12:73 on street tires and the weather was great and track was prepped.......only change from that day to this day drag radials day was cool and track was again prepped...it was $40 to run..
Usually when we go to test and tune it's $20 and no track prep ....
Thanks Gary .....I wanna hear some more times outta that thing of yours too.....we would have a great race ......
Thanks Jeff..... Yep we always have fun out there it's more fun when u can get the car quicker ...now I don't feel so left out behind Andy and Ernie....I'll never be as quick as those 2 but it feels good .....lol... We need to make a road trip........
Hey CNC, what kind of vacuum are you getting with that cam?
Nice setup BTW!
69 GTO 67 Firebird 400 |
