Ride Height Adjustment Questions
Hey guys,
I have a tube chassis 64 GTO. It is set up with a strut front end. I am considering adjusting the ride height up about a 1/2 inch to 1 inch on the coil overs. I want to do this because I have a Moroso 8 qt pan on the engine and it is closer to the ground than I am comfortable with. My real question is will raising the front of the car this much affect the launch or handling characteristics of the car going down the track. The chassis works extremely well as is and I do not want to screw that up. Thanks in advance for any help. |
If your chassis works well now, the short answer is 1/2 inch rise won't change much. But your question brings up many variables that need to be addressed.
How much upward travel do you have? Do you use limiters? What shocks do you have and how tight are they adjusted? Does the front have much bump steer and if so, where does it occur? What ET are you running? You should plan on re-aligning the front after the changes. One inch could make a much greater difference than 1/2", depending on many of these factors. Give more information if you would like definite answers.
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142 Last edited by cosgrove; 10-26-2016 at 06:13 PM. |
If room, perhaps raising the motor might also be an alternative. (not a free lunch as it affects things too!)
One factor....if you adjust the front, be sure to do absolute identical adjustments both sides. Even a small difference will change your corner weights a surprising amount.
Small tweaks in the front side-to-side bias are handy for getting a chassis car to do a straight burnout. Eric
How tall are your front tires?
How much ground clearance is there now from pan to ground? Probably have to re-scale the chassis and probably rear suspension will need redone. (4 link bars adjusted)
probably be cheaper after all is said and done, rescale, track time to adjust launch, handling, fuel, etc....just replace the pan with a shorter one.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Went with the Canton GTO pan after smashing too many Morosos. Nicer pan and better ground clearance.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
I only have a couple of more races this season. I will probably change engines this winter and will probably put a shorter pan on it. I was hoping that it would be a quick fix but I guess not. I will also probably put a little taller front tire on it. It only has a 24.5 inch MT Front Runner on it now. Thanks to all of your input...I do appreciate it.
Not a whole lotta room for that either.
Probably the route I will go. I like the low slung appearance the car has now.
Is that the kick-out style pan? I would really like to have one like that.
contact www.Kevkoracing.com ...you may be able to send your pan and pickup to them and they can fab it anyway you want it since it is a tube car, (assume it is open underneath the pan). They made me a killer circle track pan, with kickout and the price was great.
Take a look at the Canton 15-444. It is only 8" deep.
http://www.jbp-pontiac.com/products/...ns_access.html
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
You would lose upward travel if you raise ride height, so it would be important to know how much travel you have. If it is say 5", losing 1" might be just fine. This is where removing limiters would come into play as well. Tightening the front shock extension can let you get by with less travel, assuming you can still keep it hooked. I asked about E.T. because faster cars will react to subtle changes more than slower cars. I would say your car falls in the faster category, so small changes/ testing and recording are essential. Back to your plan to leave ride height alone-double adjustable shocks on the front can slow down a hard landing by tightening the compression setting. A stiff compression setting will help protect your pan. When the chassis is working right, the front compression function isn't important for much else.
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142 |
