Best big brake upgrade for 2nd gen
What is the best front and rear big brake upgrade you can do for a 72 formula with rear parking brake.
I like to hear the pro's and con's from the sets Front 17 inch rims rear 18 inch and if possible for a decent amount of money. Thanks, Daan |
I put Wilwoods on my 67 and they have been great. I did have a number of issues during the install but nothing to bad.
http://forums.maxperformanceinc.com/...d.php?t=512542
67 Firebird Convertible |
We make a nice drum-in-hat rear, goes well with the 1LE fronts.
Uses a better caliper than the S10/LS1 rear too. |
Scarebird,
I updated my 10 bolt with moser 7900 big ford bearing ends and 30 spline axles. Will your kit wotk with those upgrades too? |
The best is to use the AFX spindle and a C5/C6 brake kit. Choose a brake setup that has a bracket that fits your rear housing so you have a matching set. Wilwood has the most available options for rear brake setups, but there are others.
probably not.
Better off with a nice 13" front kit and a D154 or Dyna lite rear kit since you have the ford bearing
www.pro-touringf-body.com |
But you are correct, the more affordable approach, if braking is the key upgrade you're trying to obtain, would be to use a 13" setup. IF, you DO upgrade the brakes, and use the OE control arms, those things will flex like heck. They flex with the OE brakes and skinny rubber. I would strongly recommend the aftermarket control arm upgrade even before a brake upgrade. I'm sure you will agree, with a decent brake upgrade, cowl deflection is also a concern, so the braces would be a good idea too. .
Can you explain to me what " cowl deflection " means?
I'll probably go for the wilwood dynalite billet 4 piston callipers and 12.19 rotors front and rear, would that be a good choise? |
The Herb Adams handbook is a great starting point for anyone who wants to build a 2nd gen for performance handling. There are braces, sometimes called 'G' braces, that create a triangular framing, from the cowl to the front upper control arm mount point, which drastically reduces cowl deflection. Herb Adams made them in the 70s, and Pro-Touring F-Body makes some these days. Believe others make them too. Here's a thread on Pro-Touring.com that might be of some interest: http://www.pro-touring.com/threads/1...or-extreme-use That's a fairly new thread, search there, and you will find a bunch of other mods and discussions regarding 2nd gen frames, suspensions, etc. .
Ram Air Restorations has a better design for the Y-bar where it attaches to the cowl.
tnx
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
Yes, it will work - even better with the stock disc axles.
LOL who do you think makes those, so they are not a better design they are the exact same!
Stock single large piston calipers have more clamping force than the Dynalites (you only count 2 of the 4 pistons as they have an opposite force ) Your stock rotor is 1" thick, the Dynalite kit uses an .810 thick rotor. Dynalites in the rear are fine as long as you don't have C-clips anymore.
