Flex plat witness marks ??
Pulled motor for new oil pump & cam and spotted this on flex plate.
Flex plate flexing on hit? I leave on brake at 4.5K... Fresh PTC converter on relatively new TCI plate. No limit bars & front plate only. Note: used .062 washers to set pump engagement. How did it touch with that clearance ??!!
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Pontiac Powa?!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
I wiped a pump and crank thrust from too little pullout clearance in my learn the hard way days. I had thought it was supposed to be minimal pullout. |
I would almost like to say , no way. .060 from the bolt holes to where there is witness of contact is crazy close for a .06 gap. But I don't want to call ya a liar either. Lol
Crazy stuff going on there.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
What is that ring the bolts are in on the flex plate?
What is the situation with your transmission cooler lines? Can we see a picture of the front of the convertor?
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142 |
Kind of blew my mind why I saw it. Beginning to think about some wierd harmonics going on ?? Going to give PTC a shout.
That was a couple of the washers that stuck to plate.
Will get picture when I go to shop. Beginning to think car is haunted. 😃
Is there any chance the cooler is restricted? High oil pressure in the convertor will push it forward. I would take the flex plate off, bolt it on to the convertor with your shims in place and judge if it is even possible for the flex plate to bend in such a way that it could leave those marks.
So... I'll try to clarify... With convertor bottomed in pump there should be .125" MINIMUM gap between convertor bolt lugs and flex plate.. Maximum clearance is .1875" As mentioned a restricted cooler or excess pump pressure from too stiff regulator spring or stuck regulator can force convertor forward or swell it. Lastly...lose the TCI and use something better. CSR, JW, or...anything but TCI |
Motor plare-and mid plate ? What trans mount ? Travel limiter on motor ?
Thanks for replies
LOL, CRS...I think they make pills for that...now if I can remember who makes 'em...
