I am working on bolting up a set of KRE Highports on my 463. I have never ran KRE Heads before so I was wondering what Spark Plug Recommendations you all would have. It will be a 14 to 1 compression engine and will run on probably 112 octane. Thanks for your help.
I use NGK 8 in my heads with 13.8 to 1 with VP113.
71 Lemans Sport. 72 Lemans Sport. |
NGK V-Power..... Cold= R5671A-11.... Medium=R5671A-8.... Hot=FR4....thats the 3 NGK plugs that Kauffman recommends for the high ports, it also has alot to do with what ignition combination your running as well as compression type of fuel ect. ect. Were running the NGK R5671A-8 plugs in my 850+hp 461ci with high ports with 13.5:1 compression on 112 and ignition is a MSD power grid, pro billet distributor, crank trigger and MSD HVC-2 coil and everything seems to be great, plugs are burning nicely, idk but I've always been told with a hotter ignition go with a colder plug and I figured id try the middle of the road to start with and its done well.... best of luck, your gunna love the high ports there sweet heads...
another common plug used are Autolite 3924
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
I heard Splitfire plugs are worth 5 HP
J/k
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
LMAO thats like my damn old 5hp Briggs lawn mower made 6hp when I switched plug from Autolite to a Champion lol
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
NGK 5671-8 All motor
5671-10 or -11 if your sprayin'
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension. 5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos |
![]() Quote:
Sounds like the -8 may be the way to go for me since it is N/A.
Thanks to all for all the advice so far.
