Old 07-01-2016, 03:33 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Default Removing over spray from exhaust?
How do I get over spray off my exhaust pipes? I also have some on my painted frame rail.
Suggestions?
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 07-01-2016, 03:56 PM
steve v's Avatar
steve v steve v is online now
Lacquer thinner, steel wool or scotch brite in that order.
If you're not fussy about it, silver paint over the blue!
Old 07-01-2016, 04:15 PM
AdamIsAdam's Avatar
Sounds easy enough. What about the over spray on my painted frame?
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 07-01-2016, 10:59 PM
mtnbktrek mtnbktrek is offline
little thinner on a rag for frame then agree on what he said above
1968 LeMans Convertible - 462 w hydo roller comp cam forged flat tops- 6x-4 heads- performer intake - 800 cfm QJ- edelbrock 110 gph mech fuel pump- 4 row copper rad- followed by a Th400 w/2300rpm stall then a nodular 10 bolt posi w 3:90 gears ( need 3:55 bad
Old 07-01-2016, 11:13 PM
AdamIsAdam's Avatar
Ok 👌 thanks
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 07-06-2016, 07:04 AM
I had some heavy primer and paint on mine. I used aircraft stripper on a rag and it wiped right off. No need for scotchbrite, steel wool, etc.
Old 07-06-2016, 09:14 AM
Get the wheel off, clean it up and repaint the frame, and the fender well. It can look good when the frame is painted, then mask the frame and fender and get some undercoating spray for the fender well. I can't STAND over spray where it shouldn't be.
Bill Nye.
