Share your fuel system setup
Just curious what folks are running. Not a pissing match this is better than that, just would like to see what everyone runs for comparison.
Share your engine CID and approximate trap rpm (et's if you want to share?) Carburetor style (4150, 4500, etc) and CFM Fuel pump (make and model, any other pertinent info) Fuel filters Fuel line (feed, and if applicable return) Regulator and Fuel Pressure Dead head or return system Still getting mine together, but planning on 535 Eheads motor, approx 7500 rpm? 4500 1050 CFM Magnifuel prostar 500 w/filter (Not decided on other filters yet) -12 from cell to pump, -10 from pump to regulator, -8 dual feed from reg to carb. Magnafuel 4 port reg (2 ports blocked off)(pressure will be set once it's all together)
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Your system is exactly what I have on both my cars. 13:1 540 on e85. You should have no issues. Even if you add nitrous
Your carb will be small for max Hp. I have a 1250 |
444 CID
Factory Block, 4.180 Bore, 4.050 Stroke Wenzler Tunnel Ram 2-750 Carter AFB's 11.5:1 Compression Trap RPM 7100-7200 Fuel system Magna Fuel Prostar 300 with filter -10 feed to pump -8 return pump to cell -8 to Magna Fuel Regulator -6 to each carb
525ci- 7200 rpm Aeromotive A2000- no fuel filter- 2 #8's from fuel cell into Y-block with a #10 out to fuel pump. #10 up to deadheaded large Holley regulator out to 1050 Dominator w/ #6. .
Methanol going 5.88 @ 116 @ 3250 lbs. Hopefully 9.20's this year at Norwalk.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion Last edited by Probird; 06-30-2016 at 11:55 PM. |
12.5 to 1 comp 474 cu.in. trap rpms around 6000-6200.
127 mph. Holley HP150. Pump , #10 braided hose from a fitting in the bottom of the tank to a Screen filter, 1/2" alum. From outlet of pump to the front. #8 braided hose to the regulator. 1050 Dominator carb on 110 octane gas. I can't remember the formula, but an engine needs a certain amount of fuel by weight per hp. I flowed my pump through the regulator and it has more than enough fuel delivery |
OK, this will be amusing to some.
350P 40 over, Stock tank, 3/8 supply, factory return, stock replacement pump, dual feed into QF 780 VS. Best mph was 98 with a 2.3 60. Bam! THAT just happened!
12 gallon cell,Holley Black, to a big holley reg, 6 psi whole run from start to finish.
Enjoy! |
Dan have you been out this year?
535 12:1 shifting at 6000 and trapping at 6100 (1/4).
4500 dominator(s). Currently using a Quick Fuel 1050 and previously had a 1250 cfm with no difference in performance between the two. 10 teens to low 20's, low 6.40's in chitty summer weather. 10.0's, high 6.30's in nice spring/fall weather. Magna fuel 500 pump and filter combo with a #8 return. 2 #8 lines out of the fuel cell (15 gal) to a Y block then #10 to the regulator (Magna Fuel big port). #8's out to the carb. Pressure set at 7lbs and never fluctuates.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
407, 11.5:1, Pro Systems 750, 6500 rpm's sustained, longest straight is about 3/4 mile.
From a 22 gallon cell, -10 line through an inline filter to RobbMc 550 pump, -8 line to smaller micron inline filter, -8 to carb. No regulator, no return line. I call it the KISS system.
https://www.facebook.com/Outlaw-Vint...7899333725868/ |
Later this month I hope. Finishing up some reinforcing of the rear suspension attachment points.
440, KRE 310s, 11:1, Shaker 950HP, RobbMc everything: 1/2 sending unit, 100 micron filter, -10 to RobbMc 1100hp mech pump, 40 micron filter to RobbMc deadhead reg...
93 pump gas KISS system that keeps a smile on my face!
US Air Force Retired "FREEDOMBIRD" |
DCI RAV 535 CID Fuel Injected, twin 88m turbos.
105mm Accufab throttle body 235lb/hr Moran Injectors Drawing is close, due to space/fuel line routing constraints, each tank has a 75 Micron filter installed before the tank shutoff.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
10.90s @ 124 6000 shift 6200. 0.030 pump gas 455 E heads KRE 320 cfm CNC ported. Stock tank pickup 3/8 no sock -6 to Mallory 140 since stock pickup hard line is 3/8. Then -8 to Mallory dead head regulator, -8 line to Holley 4781 on a Torker II. 6 psi at top end.
468 shifted at 6000-6200 when needed (#3400 ) five gallon cell, -8 front to back, SS filter, small Holley regulator dead head. Holley black (140 gph) 850 DP on E-85.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Per Aeromotive website...a N/A motor needs about .5 lbs of fuel per hp. So a 600 hp motor need 300 lbs of fuel per hr. Gasoline weighs 6.1 lbs per gallon. There are some other variables they mention too. Just flow test your system for 1 minute into a gas can, make sure you flow it through the regulator.
Test your fuel system by obtaining a 1-gallon gas-can (do not use a molded-plastic gas container, or marked super-jug, or antifreeze-jug, as you will not get accurate readings). Open up the top of the tin can and insert the two or four carburetor fuel lines from your regulator, switch on the system, and carefully measure the time it takes to fill it. High 10-second cars will need to pump 1-gallon in 25-seconds or less. A 9-second car should fill the can in 20-seconds or less, 15-seconds is all it takes for an 8-second car, and under 12-seconds for 7-second vehicles. Important Note: It is essential to observe two strict rules during the test. One, keep a fire extinguisher handy and two, do not carry-out the test by yourself. 1/4 Mile E.T. Time to fill a 1-Gal. Can 7 sec under 12 seconds 8 sec 15 seconds 9 sec 20 seconds 10 sec 25 seconds 11 sec 30 seconds 12 sec 35 seconds
Thanks Darby. I'll give that a try too
