5 point harness mounting
Ok guys I have been researching this like crazy and even calling harness companies with mixed answers to a extent. I am installing 5 point harnesses in my 72 lemans sport. I installed a 8 point rollbar and plan to use wraparound shoulder harnesses to the crossbar. The problem im having is on the lap belt. If I use the factory seat belt holes I will end up pulling on the harness ends at a severe angle. It's been suggested to install eyebolts in the factory location with clip in connectors on the harnesses.this idea seems like it would work good on my outside connection but the inside connection would be pulling on the eyebolt at almost 90 degrees. Is this ok? I want this to be installed correctly the first time and most of all safe. Open to suggestions thanks in advance
I used a fabricated angle bracket on the outboard side (to go from the flat floor to an upright attachment) but no bracket on the inboard side.
The seat belt attaching end lays on the side of the tunnel and shoots generally upward and forward. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Along these lines, are wrap-around-mounted or bolt-down-mounted harnesses preferred?
Does the "rule book" specify one way or the other depending on level of car? Hi-jack not intended...
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Never pull on an eyebolt at 90 degrees. GTO George |
This is what I have done as well.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
