ATI vs TCI vs other on Flexplates
If you've read any of my other thread on Starter shims with an IA2 block and a RobbMC starter, you'll read that I lost teeth on my TCI Flexplate. I was under the impression that the starter pinion was suppose to be the sacrificial piece instead of the ring gear on the flex plate but thats not my case.
So which Flexplate is everyone using? Success, failures, your opinions. I was thinking about going to the J.W. wheel but can't get one of them possibly until June! The Meziere seems to be a little more than what I need at this point but not ruling that out. The TCI is available now but after I've seen how "soft" the ring gear is, I'm not to thrilled in using one of them again. The ATI plate is also available now but couldn't find anything on it for quality, failures, issues etc. Any and all input greatly appreciated.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
I have a TCI about 8 years old no issues.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
I hadn't heard any negative comments on the TCI flexplate so I sprung for one after going though 3 other brand x ones in as many years. with the TCI I have lost 2 pinions and mangled one. Flexplate was scared some but very usable. Just touched up with a file. Still no issues.
Would be curious where/how the bad mouth occurred. Just saying. Having said that Rob, how old is your TCI ? Maybe theyhave a new version?
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
My TCI was purchased new in the summer of 14 when I was putting my car back together. I did a search on PY and found several people had issues with TCI spitting teeth. The ring gear on it looks beautiful..except where it snapped teeth off of it.
Think I'm going with an ATI this go around, read nothing but good things about them except for Probird having to open the holes up a touch. Just pissed that I'm having to do this already. Ran an el cheapo Scat/Cat on my old motor forever without any issues.
i lost a tooth on a tci replaced it with the ati. it is a very nice piece and not too pricey compared to the jw if i remeber correctly
The ATI was $50 cheaper than the TCI and made in the U.S.of A. Not sure about the TCI, probably US made but after loosing teeth when it probably shouldn't have, I'll try something different.
I run a ATI in my 63 with no issues. Lost some teeth on the previous TCI.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
The only issue I've had with my TCI is the sides were mislabeled from the factory. One side was labeled "this side towards engine" or some such, but it was wrong. It's impossible to put it on wrong, but it made me wonder. I called to tell them, but they didn't seem particularly interested. Other than that, no operational issues with TCI flexplates. I'm due to replace this fall and I'll probably get another TCI.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Yep, other than the bolt holes too small the ATI has been great since I put it on around 4 or so years ago.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Prior to installing the motor mach up the starter to block and check the clearance on four quadrants around the flexplate. Get the shim right and you won't have a problem. Usually the problem is bad installation rather than bad parts.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
reactor
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
I recently had to replace my second TCI flexplate. Both were well used, 4-5 seasons at least. My guess is the teeth get work hardened after a lot of usage, and eventually they are brittle enough to shear off. I installed an ATI this time around. It seems like it is closer to being perfectly round when compared to the TCI's I've used in the past, and it cost less. MY 12 year old IMI starter cranks it pretty fast and smooth now, using one battery and a 50 amp alternator.
I guess time will tell the story, as far as which lasts longer.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
I just installed the SFI one I got from Butler. Looked good.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
I've been using the same TCI since 2005 with no issues.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
I broke a tooth off my TCI using a screwdriver to rotate my old low compression 400. It didn't seem like I had used excess force.
Went with the ATI. Now I just have to find the time to get it swapped out this week.
I'm using a JW wheel,good quality bit of kit,bought it used off ebay for £1 'cos the cert was up!
CSR Torque Master. Not sure if they still make it.
"CSR Torque Master Flexplates are designed to withstand the stresses of today’s high horsepower engines with nitrous oxide and high stall torque converters. Flexplate center is constructed using 3/16” thick chrome moly steel that is fully machined. With a fixture welded ring gear to ensure minimum run out and has a gold irradiate finish for lasting protection. CSR Flexplates are .062 thicker than OEM units and are double welded to withstand the rigors of high rpm racing. Torque Master Flexplates are approximately 3 lbs heavier than stock to improve reaction/and 60 ft. times. Torque Master Flexplates greatly exceed SFI. specification 29.1. SFI Certification valid 3 Years."
www.hobracing.com |
Put the new ATI flexplate in tonight. Remeasured and shimmed up the new starter and now cranks perfect. Sounds awesome! Didn't have any issues with having to open up the holes as probird mentioned. Getting to old to be doing this chit on my back.
