Old 05-07-2016, 09:14 PM
400 4spd.'s Avatar
Default Bad plug or bad switch?
I am working on a '72 A body that has power door locks. The harness plug on the passenger door switch doesn't stay on the pins of the switch. Do I have a switch that's missing the 3rd longer retainer pin? The original switch has two pins that don't extend through the plug to allow a retainer clip. The harness plug has 3 holes, so that's what I suspect.
Or is the harness end at fault? Should it lock by friction of the two pins when pushed onto the switch?
Name:	72 lock switch back.jpg
ID:	427950   Click image for larger version
Name:	72 lock harness.jpg
Old 05-10-2016, 11:31 PM
GStage1's Avatar
GStage1 GStage1 is offline
Supposed to be 3 pins on the back for each switch.
They are spring clip sockets and usually don't have a problem retaining the switch pins in them.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
