New CV1.1 head is ready
This is a good looking option for guys wanting something differant. Someone should really do a high level build with these. Hit up bill on FB
https://m.facebook.com/groups/793754...61341475760378
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Seems like we have heard this song before somewhere (and then the music died)
Tom V.
What account is that FB account?
Midwest pontiacs i think.
Midwest Pontiacs? Like Missouri or Kansas? Wonder if those are Clay Phillips heads?
Tom V.
... that the Pontiac MidWest Connection Forum on FB, the Drag Racers Page is still a closed group for now, but may change soon ...
... but for anyone interested they can contact myself or Roland for details ... (Roland) 417-209-7395 (Bill) 407-951-0410 ... the new CV-1.1's complete pair are $3500.00 ... they come std. with 2.15/1.73 valve set and flow in the 360's out of the box with 277cc intake port ... there has been a bunch of extra material added to the as cast head and the new porters casting as well, for multiple CNC port options, up to a 370cc runner with a 2.375 valve that goes 480cfm, and another nice upgrade is the ability to machine the new 1.1 heads for an 18 head bolt upgrade from a simple CNC program ... |
Thanks for the update on the FB Pontiac MidWest Connection Forum.
Have a good year Bill. Tom V.
... this is my 428 stock block combo, still used the ArmaSteel crankshaft and std. demension Pontiac rods, JE Pistons with 10.6 to 1 compression, Solid Roller with SD's full mega brace installed, my custom ex-SB2 Nascar headers flanged for the round port Pontiac, Roland Racing's new 2pc stud girdle with Comp's 1.7 Ultra rockers, this engine also had my new drive system hangin on it for testing and it performed perfectly, except for the Vac Pump, we ended up making the clearences too loose for this test, but that's being addressed currently for this engine's next dyno session ...
... The heads are a special set that i installed the CV-1.1's entry level CNC program, which bumps volume up to 290cc and this same head with our large valve big bore chamber actually goes almost 440cfm, but on the small 4.155 bore on this engine they flow 410cfm ... ... i've been a little concerned about the size of this port on 434c.i. at a fairly low compression, but further testing will show if i'm right or not, but this engine did not let us down as it made 715hp on 93 octane fuel and well under 30 degrees of total timing, the new CVI-1R finally got to be tested on this engine and unfortunately we did not have the matching CNC program for the ports in these heads, so it was run out of the box, which was quite a bit smaller than the CV-290 intake port being used, but we didn't have a choice and ran it anyways, this manifold actually extended the HP peak by 100rpm and lowered the torque peak 400rpm over the other prototype manifold that i originally built for the 428, which is a really nice piece in it's own right, so we were very pleased with the CVI-1R's results... ... but we're looking forward to testing this engine further with a different set of heads and see what she does ... |
Glad to see the new CV1.1 head is taking shape. On my CV1.0's I was able to make 906hp on my 535 with the standard low rise intake & 1050(gas) so for many that my be all they need. On the other hand the "R" manifold (only port matched) gave us 940hp & ~50 ft/lbs with the same carb. so I see great potential with the newest manifold.
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
Is your engine a Nitrous Engine Alex?
If it is you are making the same power with your engine the guy with the Pontiac engine in the Mustang was making with a two 4 intake and dual dominators. His was a NOS engine. Good Job! Tom V.
A note to anyone considering using VP's C-85 fuel - it is only E60 not the implied E85 and is a very unforgiving fuel and well known to lift ringlands of which I found out too late.
Had to ask as the low compression ratio did hurt the other guy on the dyno some.
Still with the efi and a 2000 cfm T/B you will be moving a bunch more air and the tune-up will be a bunch easier vs getting your hands in gasoline constantly. Charlie66 found that deal out when he went EFI. Tom V.
I really like the 2 piece intake. Makes porting a cast intake a whole bunch easier. Nice numbers for 93 octane and 434 cubes.
... thanks Bruce, it had some room for improvement, but i was happy with it, can't wait to see what the as cast stuff does on there and some freakin' vacuum ...
Congrats BILL!!!!!!!
Ata boy! No doubt you worked hard on this stuff a while back. Glad to hear it was finally blowing smoke On the dyno.Maybe one of these days another 2-3 years down the road you'll actually have it on the track! Congrats again! Progress is great...... My definition of progress is:Over a long LOOOOOONG period of time.....but your doing a outstanding job with it!Keep up the good work!!!!!!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.854@160.12 in Brainerd MN 7/2024 |
??? With no "tone of voice" in these forums, it's difficult to differentiate sarcasm from honest intent...
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
Can't wait to see what it does in his car...on the track!
I must have entered the Twilight Zone where sights, sounds, and time slips are blurred.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Closed Thread |
