Has anyone used a PTC spragless torque converter and what was the results. I know they say a spragless torque converter can lose .10 and 2-3mph hr over a converter with sprag if the converter was a perfect match for your combo. Was running a 8" TCI convertor sprag type (group 1 ) bought from Butler 10 years ago stalls 4900 but has a 15% slip ratio when I was running 4.10 gears, with 4.56 gears the slip ratio came down to 7% . I had PTC build me a 9" 5000 stall converter spragless was hoping to make the car a little more consistent ET wise. It's a bracket car so I'm willing to give up a little ET/MPH to run more consistent. 3350 lbs car running 10.0-10.20. 455 th-400 5000 stall 4.10 (4.33 on the self waiting to go in).
![]() Quote:
It should run the same if the converter is right, maybe faster if this converter is better.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
X2^
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Hey Jeff / Mike what size converter are you running 8"-9"-10"
8" ptc
PTC 10" spragless here.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
![]() Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
10" PTC spragless here also
6.98 @ 199mph 4.53 @ 164mph |
1100 HP into an 8" OD whorl all for momentum transfer. Still a high WOW for me.
Makes a case for higher density converter fluid. |
10" Transmission Specialties spragless convertor.
GTO George |
Tried that and talked to some different convertor companies about it. It looked to be a bit tighter at launch but rpm and slip were pretty much the same.
Hyguard
Converter flashes at 900 in the backhoes and 1000 in the scrapers.
LOL
Boobs & bacon ![]() |
