Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-31-2016, 07:17 AM
a95toy's Avatar
a95toy a95toy is offline
Default FS 72 455 91 octane street motor and trans
I am selling the running 461 ci motor with a m21 Muncie trans and all the good stuff with it. That includes the flywheel Clutch and bell housing. I'm replacing the entire drive train with a more updated motor and trans. The motor has 520 miles on it since the build. I just decided to go another direction for my 74 GTO.. Asking price is $5800 for the whole setup less distributor, pulley's and carb( it has a edelbrock performer on it that will go with motor) you setup shipping or pickup I'm unable to lift due to back problems. It is for sell locally as well....
1972 Pontiac Code YH motor..
97954 Nodular Crank
L2359NF30 TRW 30 over Bore pistons/Hastings rings
Factory reconditioned rods/upgraded rod bolts
mild port on 72 7K3 heads with manifolds converted to adjustable valve train
compression 9.37 to 1 ratio
BOP rear seal no leaks.
Flywheel is 10.5 with 10 spline clutch, pressure plate bearing all new
Oil pressure from melling oil pump with welded pickup @60 psi warm
Crank has been turned 10/10
Summit 2802 cam and lifters Duration 298/303, Lift .466/.488
Comp Cams roller tip 1.65 rockers/fits under factory valve covers
Cloyes double roller timing set
Trans
M21 muncie trans completely rebuilt new gears, bearings and seals
with Hurst Competition Plus shifter with all new bushings. Shifts are tight and smooth. The trans was out of a 69 RS/SS 396 Camaro.
Can hear motor run not pulling it until I make the sell. The new motor's not quite ready.
Call or email me if interested
ph 205-670-7073 ask for Terry/ email a95toy@yahoo.com
Name:	455ci 4 speed very fast.jpg
ID:	424920   Click image for larger version
Name:	GTO s engine 455.jpg
Old 04-02-2016, 09:57 AM
a95toy's Avatar
Default 455 drive train combo
still for sale!!!
Old 04-07-2016, 05:46 AM
a95toy's Avatar
Wow No interest in a performance street setup????
The $5800 is OBO if anyone is interested.
laters
T
Old 04-13-2016, 08:10 AM
a95toy's Avatar
Still Available....
Old 04-23-2016, 07:52 AM
a95toy's Avatar
last chance will be pulling the drive train soon.......
I will be making some vids of it running
Old 05-06-2016, 07:43 AM
a95toy's Avatar
Pulling motor next week.. Last chance to hear it before you buy!!!!
Old 05-10-2016, 07:27 AM
a95toy's Avatar
Default 455 and m21 muncie
still for sale...
Old 05-14-2016, 03:41 PM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
are you willing to sale transmission items with out the engine. Im wanting to change my 72 to manual trans. Josh
Old 05-16-2016, 11:18 AM
a95toy's Avatar
I would be willing to separate the combo.. FMile check your pm
Terry
Old 05-26-2016, 12:38 PM
a95toy's Avatar
Wow not one trade or best offer?????
Old 06-08-2016, 07:11 AM
a95toy's Avatar
Bump.....
Old 06-20-2016, 09:20 AM
a95toy's Avatar
Sold!!
