MR1 block windage tray.
I have a Canton windage tray 20-918p it does not clear the main caps. What are you guys using.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Every one I've used cracked and broke. So I stopped using them.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
This^^^
Even the Canton broke?
Yes
So no windage control at all Mike?
No tray in either of my motors
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
I didn't say that. But no tray. And a better pan is hp
There is HP is in the pan design. Windage tray for stock stuff.
Good pan photos on page 4 of Leech's "2.2 HP/c.i." thread.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
So what pan should use to fit my 4.5 stroke with aluminum rods and still fit in my 71 Lemans?
call steffs....they can set you up.
I called Stefs and they said that there pan wouldn't work with a 4.5 inch stroke.
I was looking at this one.Nitemare custom oil pan to fit 64-72 GTOs and 67-69
moroso. doug vine 203-453-6571 x315. he will set you up with a custom pan. a stock shaped pan may not fit the 4.500. then you may also run into header fitment with a custom pan
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
Here is what I ordered. I hope it works.nitemare performance.com
Ditto. Just a scraper.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
