Old 03-25-2016, 09:22 AM
gman005's Avatar
gman005 gman005 is offline
Default Wheelie bars.
Can I see some pictures of your wheelie bars? I think I will need to put them on my car just trying to get an idea of how they mount. Thanks John
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 03-25-2016, 12:29 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Nobody needs wheelie bars anymore, but if you want them mine are attached by a bracket on the rear.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
Old 03-25-2016, 01:35 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Let the bumper drag!
Go fast, see Elvis!
Old 03-25-2016, 02:14 PM
pontibeast's Avatar
pontibeast pontibeast is offline
Jack, all that is way above my power level, but what other options are there to keep the car hooking and not run on the rear tires out to 600 ft mark?
Old 03-25-2016, 02:20 PM
slowbird's Avatar
slowbird slowbird is offline
It gets pretty darn expensive that 1 or 2 times you do need them. They are a nice safety net to have
Old 03-25-2016, 03:28 PM
Tom Vaught's Avatar
Boost Engineer
Few, if any can do a Arnie Beswick launch, (where he thought the Wheelie Bars were reinstalled back on the car (after some maint), and were not, the car points at the full moon at Butler's event, Arnie figures out the situation, drives the car under EXACTLY the right amount of power to softly drop the car back onto the track surface, with the only issue being the crank sensor needing to be slightly adjusted back onto correct timing. Most times without the bars and a lesser driver you are talking $$$$$$$$$.
Just saying.
Tom V.
Old 03-25-2016, 04:25 PM
LiL Jack's Avatar
The proper suspension set up is key. And a good front shock is a must.
It all depends on your power level. I ran mid 9s with QA1s but you had to tighten up the limiters and shocks on a good track.
A good set of Santuff shocks will be cheaper then wheelie bars installed.
Old 03-25-2016, 05:26 PM
Tom Vaught's Avatar
Boost Engineer
X2 (even with a back half car).
Tom V.
Old 03-25-2016, 05:52 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Here are some pix of my set-up. I bolted them to an existing bracket on my four-link on the bottom and welded a couple of brackets to the rear end housing for the top mounts. IIRC, I got the kit from A.R.T. in Florida. Note: the bars are mounted in the up position in the pictures (for loading and trailering). We set them down before making passes. I run an anti-roll bar in addition to the wheelie bars to keep the launch level.
Jim
ID:	424511   Click image for larger version
ID:	424512   Click image for larger version
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 03-25-2016, 06:23 PM
gman005's Avatar
I have strange double adjustable rears and afco on the front. I don't have any limiters.
71 Lemans Sport.
72 Lemans Sport.
Old 03-25-2016, 06:26 PM
gman005's Avatar
Jim thanks for the pictures.
71 Lemans Sport.
72 Lemans Sport.
Old 03-25-2016, 06:34 PM
Probird's Avatar
Probird Probird is offline
I don't run them but have needed them a time or two. Once the car gets too high it doesn't matter how good you are with the throttle to bring it down easy it's still going to bang off of the oil pan and bend it up. My buddy has a Chevelle that loves to wheelie also. He had a set of solid bars. He hated them. They would unload the rear tires causing them spin and when they would hook back up again it sometimes broke the rear end gear. Then he had another set made that were spring loaded. Those work way better for him. Just thought I would share that if you weren't sure which ones to go with.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 03-26-2016, 09:54 AM
gman005's Avatar
I was looking at a set of spring loaded bars.
71 Lemans Sport.
72 Lemans Sport.
Old 03-26-2016, 02:21 PM
The kit that I bought was spring-loaded, but I replaced the springs with solid pipe, because I was afraid it would allow the wheelie bars to hit the chassis, given the way it all came together. The wheelie bars have worked fine so far without being spring-loaded. If you watch the u-tube video of my first seven-second pass (in my signature), the wheels appear drop down to the ground right away and stay there for a while on that pass, doing their job well.
Jim
7.75 @ 178 pass:
Old 03-27-2016, 12:31 AM
Money Pit's Avatar
Money Pit Money Pit is offline
Menscer Shocks = no bars
Old 03-27-2016, 08:02 AM
slowbird's Avatar
No fast cars run spring loaded wheelie bars that i know of. If you're hitting the bars hard enough to unload the tires then you need to work on the suspension. The bars should be there for safety mostly. Like LilJack said get the right shocks and the bars should rarely touch. The car will be quicker also if you keep the front down.
Old 03-27-2016, 09:15 AM
gman005's Avatar
I have to get the new motor in the car and see what I need to do.
71 Lemans Sport.
72 Lemans Sport.
