Tanks Inc EFI Tank for 68 Firebird
This is the Tanks Inc EFI Tank. Just showed up tonight. All parts look very good to excellent. Tank and straps are powder coated. Has a Walbro pump.
Let us know how it goes ..... and draw up a schematic of all the lines you use and where they go.
Purdy...I have the same set-up in my 69 bird but used a a Classic Instruments SN38 sending unit instead per the advice of HWYSTR455 (Mike) who had issues with the one supplied by Tanks Inc.
https://www.summitracing.com/parts/cin-sn38
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
This may sound like a stupid question, but is there a low pressure electric pump that fits in that tank so one can run a carburetor set-up and be ready in case they want to go EFI in the future ? I'm considering going electric pump but would like to have it in the tank.
Not a stupid question at all. Just run a special regulator designed to reduce an EFI pump pressure to a carb friendly pressure. I've been running one for 10 years with an in tank Walbro EFI pump (early Tanks Inc setup) and my Cliff Ruggles Qjet.
And if you ever switched to EFI in the future you wouldn't have to touch the pump or the tank.
___________________________________ "Objects in mirror are closer than they appear" |
A few more questions.
Was the powder coat extra? What were the options as far as Fuel pump goes? Is there any tray or baffling in the tank? Have you considered running the holley hydramat? It sounds most of the high end pro touring guys do but at the same time I heard they don't last very long. |
The tank is both baffled and has a sump tray for the pump itself. A hydramat would be useless in the application because of the tray and the use of the pump sock which acts in the same way. I got my entire setup from Swartz Performance shipped for $470.00. They had a sale going on which they might still. That was the tank, pump, pump sending unit, sender, gas cap, straps and rollover vent.
I got mine through Summit Racing, they sell the entire assembly. The price seems the same as on the Tanks web page, but you save on shipping. Shipping is free, but there is a 10 dollar surcharge. 10 bucks to get it to my house seemed like a great deal. I paid 505.72 for the tank, 255 lph pump, 90 ohm sending unit, and mounting straps.
Frank. |
Yes, I fabbed up new steel 3/8" feed and return lines from the tank to the Aeromotive regulator. Then I ran a braided steel line to the Qjet with the adapter fitting.
I also run a small Autometer fuel gauge inside the car with the transducer kit. I installed the transducer in one if the extra ports in the regulator. Regulator is mounted on the passenger side wheel well next to the radiator overflow jug. I also decided to keep things simple (and sort of GM looking) by mounting a stock Buick GN type frame mounted fuel filter on the backside of the passenger frame connector. Pump is a Walbro 255 l/hr for a Buick GN and many other GM's. This setup finally cured all of my fuel issues that had plagued this Firebird for years.
Carb set-up diagram
http://www.tanksinc.com/index.cfm/pa...cat/cat163.htm
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
If you scroll down, you'll see TBI pump listed. This would be an easy pump to regulate down to carb-friendly pressure.
http://www.tanksinc.com/index.cfm/pa...rod/prd227.htm
The configuration is simple and exactly like a standard EFI setup (non-modulated). Feed and return the same size. Fuel filter on feed. Regulator maintains constant (in this case carb friendly pressure that you can fine tune) pressure to carb and returns the rest. System is constantly recirculating.
I would avoid the TBI pumps as they typically supply much less fuel. Even the one in the Tanks-inc link is only rated at 109 l/hr.
What kind of regulator would you use for a larger pump- say a 255LPh?
I'm using an aeromotive regulator made specifically for this purpose. There may be others though as I did this about 10 years ago. I think it's a 13301 or some such number. I can check it later and post but their website probably has all the latest and greatest.
Im running a Tanks Inc set up too just a different setup...still setting it up actually...
I'm using a RobbMc Regulator Great products and great service.... http://www.robbmcperformance.com/pro...regulator.html
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Here is an important tidbit from the product details. "The installed low pressure spring will adjust fuel pressure from 3-20 psi, the included high pressure spring must be installed to adjust fuel pressure from 20-65 psi." This has been in service on my Formula since @2006 and has worked flawlessly. Adjustment is simple and is basically set it and forget it. Currently I'm in the process of finishing up another engine upgrade and with that I'm addressing some general housekeeping issues around the car. One of the areas I plan to work on improving is some sound deadening in the trunk and back seat area so that the pump can be quieter and more like a stock production car. It's certainly not bad now and no where near as loud as a typical undercar pump but I feel it could be quieter and more stealth.
Thanks for the info, guys. I didn't realize the regulators could handle the output of a 255LPH pump, that's why I was thinking of the TBI unit. With this knowledge, there's no sense NOT using a 255 from the start. When I convert it to the FITech unit, it'll already be plumbed and ready!
