Old 12-08-2015, 07:44 PM
FunctionalShaker FunctionalShaker is offline
Default NEW SOURCE FOR DASHES!
Since I've been in contact with Al Knoch regarding the cushions and burlap, I brought up the idea of reproducing dashes. That said, they are now in the preliminary stages of doing so. I will probably be sending one of my cracked blue 70 dashes to work off of, but they'll need several for the process. They said they'll try to produce them in color -- I'll be pushing for the blue.
Differences I know about are the radio openings and I believe the grain of the vinyl. Do we know when the grain was changed? Anything else?
The problem in reproducing these is that they have to disassemble original dashes to make new molds -- which destroys them -- but we'll see what we can do. Also, even the nice originals generally have some warpage on the leading edge, so it'll be tough to reproduce one.
Old 12-08-2015, 09:26 PM
weranc55's Avatar
weranc55 weranc55 is offline
That would be great to have another option for these.
Old 12-09-2015, 01:50 PM
JC455 JC455 is offline
I have one (maybe two) that has a lot of damage- either cracked, or cracked and broken plastic- that I'd be happy to let them get their measurements, procedures, etc. off of.
No idea of the year- guessing mid-70's.
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 12-09-2015, 03:22 PM
71formula455's Avatar
71formula455 71formula455 is offline
Look for a date stamp on the back side of the dash around the glove box area. . I think.
71 Starlight Black Formula 455 L75
88 Flame Red Metallic GTA Notchback
Old 12-09-2015, 06:40 PM
The goal here is to make a repro. of an earlier dash. They'll be using my 70 dash for the frame structure. I was told they wish to produce them in black and bright blue. It's cost prohibitive because the colored " ABS plastic" used for the skin can only be purchased in 1000 yard rolls. At $22 a yard, that's $22,000. They'll try to match the early grain texture. At this point -- still early -- cost estimate is $550 - $600 per finished dash.
Old 12-09-2015, 09:17 PM
Guess I'll hold off on painting my repop dash and installing.
Any idea on a timeline?
1974 Formula 400 - Ram Air automatic
Old 12-09-2015, 09:26 PM
Cool. But given that the bright blue is a one year only color with therefore limited demand, I would imagine the economics of producing them in that color won't be very good for the manufacturer.
And, no matter what, the rest of your dash parts (glove box, steering column shroud, ash tray) will need to be matched by dye-ing them. A good match will be difficult to achieve. Easier to just re-color them all at the same time so they match. And that means starting with a bright blue dash pad isn't of much value. JMO...
Old 12-09-2015, 09:34 PM
2manyT/A'S's Avatar
And don't for get that the other dash parts (in blue) didn't really match the pad either...
Eye Candy......garage band?
Go full screen & turn it UP!
Old 12-10-2015, 12:20 AM
Nothing matched when the cars were new...
Old 12-10-2015, 03:32 AM
2manyT/A'S's Avatar
Without being negative here.....
As soon as there is a second source for these dash pads......Classic Industries will ramp up production and FLOOD the market with them for $150....
Not a BAD thing for US....but Al Knock will end up "eating the weenie"...and loosing his investment......with NO profit margin....just sayin'
Old 12-10-2015, 10:03 AM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
I know Just Dashes is expensive . But who here has used Just Dashes to restore their dash pad? If so how did it turn out?
Atoll Blue, Blue interior, 1970 RAIV Judge/4 spd/ 3.90/ pwr steering/ pwr brakes/ hoodtach/ gauges/ sport wheel/ console/ remote mirror/tinted glass.
Starlight Black, Camel Tan interior, 1978 Trans Am . Auto/AC/door edge guards/ am/fm, Cassette stereo/ floor mats frt and rear/Hurst Hatches
Cameo White, Blue interior, 1971 Trans Am/4spd/ Am/Fm/ power windows / AC. 28,000 original miles
Old 12-10-2015, 12:26 PM
2manyT/A'S's Avatar
Just Dashes appears to be the "default setting" for anybody doing a high dollar car...with NO budget restrictions...
They ARE nice.....but like a cap...you can usually tell.......they can look slightly "overstuffed"......and fitting the bezel can be tight
Old 12-10-2015, 02:12 PM
I had them do my lower door panels and was very happy.... now my interior is 5 shades of blue.
I was leary about having them do my dash as I didn't want bezel fitiment issues. My original dash is pretty rough and butchered. I'll probably just throw in the repop POS in and call it a day.
Anybody have any comments on the repop 4 speed console kit that Ames sells? They note that the dash bracket is plastic and the mounting holes might not line up. I pulled my console to install the dash and noticed my console is in worse shape than I thought.
Old 12-10-2015, 02:36 PM
weranc55's Avatar
If you think the dash is a POS you will think the console it the biggest POS you have ever seen. I have used the repo dash pad and have not had any problems with them. The repo console is not great but with some work you can make it decent. You will have to take your old bracket off and use it. We actually panel bonded it and then put the two fake rivets on the side. It has a ton of grain in it but we used a primer and then blocked it and got most of the grain out and then dyed it.
Old 12-10-2015, 03:16 PM
2manyT/A'S's Avatar
I've heard that mounting an 8 track in the repop console is a chore....
Old 12-10-2015, 05:43 PM
Probably better off repairing my original console.
Old 12-10-2015, 06:35 PM
I think the reason they want to do the blue is that they have bright blue plastic sheet in stock from a corvette project. They're going to send me a sample to look at. I'll ask about production time. I do know they won't be starting until Jan.
I just spoke with them again and was told they have the bright blue material they use for the arm rests etc. to use. Apparently they've made a number of tough dashes (Cuda, Challenger working with Year One) and have gotten pretty good at it.
Initial Production/development time could be from 2 to 6 months.
Old 12-10-2015, 07:29 PM
I'm a buyer!. I'll hold off on installing the repop dash that I have now.
Old 12-10-2015, 08:10 PM
bankbook's Avatar
bankbook bankbook is offline
Did the Whole interior on my Anniversary TA except for the door panels.
The work was really nice and the fitment was spot on.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 12-10-2015, 08:25 PM
I'm a buyer for a black Al Knoch early dash, just cant stomach the current wait forever "one fits all" mess. Back over a decade ago when Classic first started the project, was like which one are they doing?
Thank you Harold for getting this going with Al Knoch, ready to order when they get them going.
