Holley Sniper Vs Fitech TB EFI
I plan to purchase on of these EFI systems.
http://fitechefi.com/default.asp.pg-Products https://www.holley.com/products/fuel...on/sniper_efi/ I have researched both of these products and they look to be very similar. I don't know as much about the holley, but the response that I have seen on the fitech is nothing but positive. I get that these are simply a carb replacement and not a performance enhancer, my hope is to get a little more accurate "tune" of my car and some reliability in starting it as my Wife will be driving this at times. The March release date works fine for my needs but would like to have everything up and running by May.............we will see! Any thoughts on either of these two systems? Holley look like it may have some more bells and whistles, but the Fitech sounds to be very well developed.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
Is the holley actually for sale yet? Original word said should hit the market early 2016 I think. So I dont think there will be much side by side comparison yet.
The fuel command center might be a sell point for some on the FItech side. I had heard some Terminator or FAST Efi users had adapted Edelbrocks similar fuel system for use. Holley may now have their own version, Im not sure.
Holley is taking preorders, but not shipping till April of 2016.
Agree about the command center. looks to be nice system and would likely use that with the sniper if I went that direction.
Since your in MN. and this is probably a summer car, If you go FiTech, wait till they release the newer version with the Bosch 4.9 sensor, it is a bit more accurate. Don't have any details about the Holly yet.
I think people will find that both will serve their needs. Holley generally has pretty good product support and so far FiTech has been awesome to deal with. They are always available if you need something.
The bodies look very similar and it wouldn't surprise me if they were both coming out of the same factories. The FiTech unit is from china but I don't have a single concern with the unit they sent me. It's quality is more than I expected based on the price point.
I wonder if the Holley system will fit the stock manifolds and shaker/ram air air cleaners better.
I would bet they are very similar if not the same height, not sure about the drop base causing interference though.
You're likely going to run into the same fitment issues on factory intakes and with shaker cars as you do with the FiTech EFI. Although a few have made it work with modification. for reference. Sniper EFI: FiTech EFI:
The screen on the Sniper unit would suggest that it may have more functions than the FITech.
I don't really have any complaints about the FiTech handheld, but a nitpicky thing is that if you select less than 4 real time displays for large gauges, the screen doesn't scale to fit things in a great manor. For instance, if I selected only 2 items (water and vacuum for example) it would give me water and vacuum and a whole bunch of extra blank space, instead of making those gauges larger to fill the entire space. My solution is just to monitor 4 items. Myself I monitor water, vacuum, volts and AFR.
I have nothing but good things to say about fitech. My unit is up and running and ever time I call them I get to talk to some body that can answer my questions. I would not hesitate to buy from them again.
Does the FiTech require vacuum to operate? A lot of 550-600 HP motors will not have much vacuum. The Sniper requires 8" vacuum to work. It does not support boost or NOS. It does require a water and O2 sensor. It will control timing with the right distributor. Don't know where its made yet. And 90 day warranty.
I do not think the fitech requires vacuum. I have it on my car and it shows vacuum less than 8 when running
The basic FiTech unit does not support boost or nitrous controls. That's not to say you couldn't use nitrous with it, but the basic unit won't trigger it or retard timing etc. For that you'd want to step up to the Go EFI 8 or GO EFI boost if you don't need support for more than 600hp while using nitrous or boost.
I will get an Fitech system. All other things being equal, I like a competitive player in the market that ISN'T owned by Holley.
Unfortunately, it probably won't be long before Holley throws a big stack of cash at Fitech and buys them out anyways. Buy a competitor out when they are small so you don't have to compete when they are bigger, AND you inherit their proprietary tech.
Holley is also selling a new system called Terminator Stealth for the same price. Not sure the advantages or disadvantages to the Stealth vs the Sniper.
For your viewing pleasure, I enjoyed watching this.
https://www.youtube.com/watch?v=iry0QhiuulM |
I emailed Holley to try and get some more info. They did not send me the specs I was looking for, but did get this response.
- Hello, The Sniper EFI will use the Bosch 02 sensor. The Unit will have 2 full manifold vacuum ports 1 timed vacuum port for vacuum advance distributor. It will have 2 fan outputs and 1 fuel pump output and 1 A/C kick output. Yes we are taking preorders and should be available 4/30/16. Thanks Shane Whitescarver Technical Service Representative
Is it just me or would anyone else feel better about the Holley Sniper if the opening was blended like the FiTech?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
